confused about data usage
"When we used Comcast as our ISP, their rep told us that we only used about 2% of our 10G plan per billing cycle."
Never heard of Comcast having "plans" let alone a 10G one. Their service is usually 200-250GB across the board from what I understand. They are cable, not satellite.
They have different speed plans but the amount is the same, quite high.
I'm wondering if maybe it was a 10Mbps plan, as doing a Google search shows that they may have, or have had, something like that. Something called Comcast Internet Essentials.
GabeU wrote:I'm wondering if maybe it was a 10Mbps plan, as doing a Google search shows that they may have, or have had, something like that. Something called Comcast Internet Essentials.
VortecCouple seems to be conflating data amount with speed, two very different things. Again like you say, should repost under different topic like Tech Support or Products and Plans, this is the billing section.
VortecCouple, do you have a problem with your billing?
- HughesNetSucks48 years agoSophomoreNeither of you were helpful at all to VortecCouple. Aren't you here to help? Telling them "post your comment in another category" does nothing for the customer, and they should be your top priority.
First, this is not the tech support site. Data usage is a tech support issue.
Secondly, please stop spamming.
