Was lied to when and want to cancel
The reps can likely have a sales call review performed. However, they'll need specifics regarding what you feel you were lied to about regarding service usage and what you can do with your service.
The reps are on Monday thru Friday from 9AM to 6PM EST, so you should see a reply from one tomorrow. They may need some personal info from you in order to locate your account, but they'll ask for it to be sent via Private Message.
- Cwright303 years agoNew Poster
Great cause I was told we get 30 gbs a month and once that’s gone we would not be cut of it would just slow down a little bit that’s not the case one the 30 gbs is gone we can not do anything and I was never told it was. 2 years contract
- Damian3 years agoModerator
I understand. When it comes to how data usage works, what was relayed to you is accurate. It is very possible that there are outside factors on top of running out of data that may be simulating a no connection issue when it isn't or at least isn't from being "cut off". Figuring out what is causing those types of issues would require technical troubleshooting. As far you not being told about the length of the contract, this can be reviewed. We will certainly look into requesting your sales call for review to determine whether the sales rep set the appropriate expectations. I'll post back once I get the results.
Your patience and understanding are much appreciated. -Damian
We have called in about the internet not working and thank you
Please send me a private message with the phone number associated with your account. You can use this link https://community.hughesnet.com/t5/notes/composepage/note-to-user-id/76644.
And no worries GabeU the information was accurate 👍. -Damian
