Quinatt
6 years agoFreshman
Data tokens vs plan upgrade
First month with hughesnet. On the 10gb plan and I see that the upgrade to 10gb more is only $10 more. Then I see to purchase 10gb tokens is $30?? Can I not upgrade my plan mid month for the $10 more...
Quinatt
6 years agoFreshman
Ok that’s a relief to know. I guess the only reason for buying the 10gb for $30 would be for someone already with a big plan. Good to know.
Would steaming a YouTube video even be possible once the data is used up and it drops to a slower speed? Probably different for each service, depending on your signal strength to begin with?
Thanks for your replies. Satellite internet is a pretty terrifying thing for people who aren’t wealthy
"Would steaming a YouTube video even be possible once the data is used up and it drops to a slower speed? Probably different for each service, depending on your signal strength to begin with?"
If you're out of data, then streaming is pretty much a no. When you have data, streaming works no matter what plan you're on. BUT, it is highly dependent on congestion -- this means if a lot of people are using the system in your area, streaming is harder, and sometimes impossible.
