MarkJFine
8 years agoProfessor
Experimenting with Alternate DNSs
Currently using CloudFlare: 1.1.1.1 1.0.0.1 2606:4700:4700::1111 2606:4700:4700::1001 Have set the router DNS as well as on devices (initially). Eventually I think the automatic should pick u...
MarkJFine
GabeU wrote:I'm not really versed on the kind of things you do, but does your post mean that you would not recommend the use of Cloudflare for a DNS service for the average user?
Not sure what was really causing it, so it's more of a use at your own risk, your milage may vary.
Well, I don't know if it had anything to do with Cloudflare's DNS, but a little while ago I was having a heck of a time signing into DirecTV's site to pay my bill. After a bunch of tries and getting error messages and such, I changed the HughesNet modem back to Google's DNS, unplugged the same, flushed the computer's DNS cache, shut it down, restarted the modem, then the computer, and everything worked just fine.
I'm sticking with Google's DNS.
