Google problem?
Nope, nothing. Are you still having the problem of slow loading of FB pages?
GabeU wrote:Has anyone else seen any issues with Google over the last week or so? Sometimes when I simply try to open the page it takes forever, while any other web pages are just fine. And, when I try to search using Google, the searches sometimes take a very long time while, again, the rest of the net is fine.
Nothing "fixes" it. When I check "IsItDownRightNow", which I can sometimes do in less time it takes for the Google page to load, it says Google is fine.
Again, no other sites are affected while this is happening, just Google.com and the searches using it.
Just curious if anyone else was seeing this.
Interesting. I keep forgetting to check the page load time when it happens, but I'll try next time.
Facebook is fine now. I don't know what was going on with it, and as far as I know HughesNet didn't tweak anything, but it's been much better over the last few months. It's still slower than most other pages, but with so much to load I would expect it to be.
Have you run a tracert?
maratsade wrote:Have you run a tracert?
Not while it's happening, no. I think when it happens again I'll quickly try a ping. Then, if it happens again, I'll try a tracert.
This is while it's working normally. Not sure what that 3rd hop is.
I'm convinced the whole internet is messed up. Chinese hackers are running massive vulnerability scripts literally everywhere tying everything up. It's a mess.
