Google problem?
Interesting. I keep forgetting to check the page load time when it happens, but I'll try next time.
Facebook is fine now. I don't know what was going on with it, and as far as I know HughesNet didn't tweak anything, but it's been much better over the last few months. It's still slower than most other pages, but with so much to load I would expect it to be.
Have you run a tracert?
maratsade wrote:Have you run a tracert?
Not while it's happening, no. I think when it happens again I'll quickly try a ping. Then, if it happens again, I'll try a tracert.
This is while it's working normally. Not sure what that 3rd hop is.
I'm convinced the whole internet is messed up. Chinese hackers are running massive vulnerability scripts literally everywhere tying everything up. It's a mess.
I didn't get a chance to run a traceroute betore the issue got better, but here's the difference...
Problem...
Normal...
Granted, 15.1 seconds isn't terrible, but for a simple page like Google it's a bit odd. Sometimes it takes a good bit longer than that. It's the same when I try to search using Google and when I do automatic searches when right clicking on highlighted text and choosing "Search Google for...."
