Google problem?
maratsade wrote:Have you run a tracert?
Not while it's happening, no. I think when it happens again I'll quickly try a ping. Then, if it happens again, I'll try a tracert.
This is while it's working normally. Not sure what that 3rd hop is.
I'm convinced the whole internet is messed up. Chinese hackers are running massive vulnerability scripts literally everywhere tying everything up. It's a mess.
I didn't get a chance to run a traceroute betore the issue got better, but here's the difference...
Problem...
Normal...
Granted, 15.1 seconds isn't terrible, but for a simple page like Google it's a bit odd. Sometimes it takes a good bit longer than that. It's the same when I try to search using Google and when I do automatic searches when right clicking on highlighted text and choosing "Search Google for...."
That's a pretty big difference, and 15 seconds seems excessive for Google.com. Something's clogging up the pipes, and maybe it's the Chinese hackers Mark sometimes talks about.
