Macro Test
See "How do I manage my built-in WiFi modem in <a href="http://customer.kb.hughesnet.com/Documents/1041318-0001_a.pdf">this PDF</a>.
I may need a new brain. ;)
maratsade wrote:I may need a new brain. ;)
Sign me up, too. :p
First, please check to make sure that you are not presently out of data, which you can do via the HughesNet Usage Meter or the System Control Center. Also, please verify that both boxes at the top of the System Control Center page are green. If you are not out of data and both boxes are green, please proceed with the speed tests described in the following instructions...
To help the HughesNet Customer Service Reps get a head start on your speed concerns, please create a testmy.net account (if you do not already have one) and, while signed into that account, perform a batch of 3-5 tests during different parts of the day, then share the account results link with us here.
For a more in depth guide on running the tests, please see this site (due to being an older site, the stated test sizes are incorrect for Gen5 (please use the test sizes listed in the instructions above, in bold, for Gen5)).
If you don't know how to disable the WiFi in the HT2000W, please see "How do I manage my built-in WiFi modem?" in this PDF. Please be sure to click "Save Settings" after unchecking "SSID Enable" for each of the four tabs individually (2.4Ghz, then 2.4Ghz Guest, then 5Ghz, then 5Ghz Guest).- maratsade7 years agoDistinguished Professor IV
And this time I'm not going to ask who you're responding to. ;)
