Macro Test
See "How do I manage my built-in WiFi modem in <a href="http://customer.kb.hughesnet.com/Documents/1041318-0001_a.pdf">this PDF</a>.
First, please check to make sure that you are not presently out of data, which you can do via the HughesNet Usage Meter or the System Control Center. Also, please verify that both boxes at the top of the System Control Center page are green. If you are not out of data and both boxes are green, please proceed with the speed tests described in the following instructions...
To help the HughesNet Customer Service Reps get a head start on your speed concerns, please create a testmy.net account (if you do not already have one) and, while signed into that account, perform a batch of 3-5 tests during different parts of the day, then share the account results link with us here.
For a more in depth guide on running the tests, please see this site (due to being an older site, the stated test sizes are incorrect for Gen5 (please use the test sizes listed in the instructions above, in bold, for Gen5)).
If you don't know how to disable the WiFi in the HT2000W, please see "How do I manage my built-in WiFi modem?" in this PDF. Please be sure to click "Save Settings" after unchecking "SSID Enable" for each of the four tabs individually (2.4Ghz, then 2.4Ghz Guest, then 5Ghz, then 5Ghz Guest).
And this time I'm not going to ask who you're responding to. ;)
maratsade wrote:And this time I'm not going to ask who you're responding to. ;)
:p
I'm creating a second speed testing macro. This one will have the same info, but with the added caveat of verifying that they are not out of data and the system is in working order (green boxes). This will make it easier if they haven't mentioned anything about checking those two things in their opening post.
Please perform the following test outlined in the graphic below. This is known as a modem isolation test, and it will help to determine whether the issue is with HughesNet or your local network..
1: Disabled the WiFi in the HT2000W modem.
2: Take a screen capture of the HughesNet Usage Meter, along with the clock on your computer screen.
3: Disconnect the LAN cable from the modem, noting the date and time of disconnect.
4: Leave the LAN cable disconnected from the modem for several hours. HughesNet recommends doing this overnight, or during the day while at work. DO NOT unplug the modem from the power. The modem must remain powered.
5: Reconnect the LAN cable to the modem, noting the date and time of reconnect.
6: Take a screen capture of the HughesNet Usage Meter, along with the clock displayed on your computer.
7: Post your screens hots to the community.
Please DO NOT unplug the modem power after running the test. The reps need to be able to reconcile the test results with the modem logs, and disconnecting the power from the modem erases those logs.
Please be aware that, if you downloaded any large files just prior to this test, or if the disconnect was for an extensive time period, some usage may appear to have occurred, but it should be rather negligible.
If you don't know how to disable the WiFi in the HT2000W, please see "How do I manage my built-in WiFi modem in this PDF. Please be sure to click "Save Settings" after unchaining "SSID Enable" for each of the four tabs individually (2.4Ghz, then 2.4Ghz Guest, then 5Ghz, then 5Ghz Guest). - GabeU7 years agoDistinguished Professor IV
1: Disable the WiFi in the HT2000W modem.
7: Post your screenshots to the community.
If you don't know how to disable the WiFi in the HT2000W, please see "How do I manage my built-in WiFi modem?" in this PDF. Please be sure to click "Save Settings" after unchecking "SSID Enable" for each of the four tabs individually (2.4Ghz, then 2.4Ghz Guest, then 5Ghz, then 5Ghz Guest). - GabeU7 years agoDistinguished Professor IV
-the testing device should be the ONLY device connected to modem while testing
-If testing upload instead of download, use the manual 3MB size upload test file
To help the HughesNet Customer Service Reps get a head start on your speed concerns, please create a testmy.net account (if you do not already have one) and, while signed into that account, perform a batch of 3-5 tests during different parts of the day, then share your testmy Results page URL with us here.
-if testing upload instead of download, use the manual 3MB size upload test file
If you don't know how to disable the WiFi in the HT2000W modem, please see "How do I manage my built-in WiFi modem?" in this PDF. Please be sure to click "Save Settings" after unchecking "SSID Enable" for each of the four tabs individually (2.4Ghz, then 2.4Ghz Guest, then 5Ghz, then 5Ghz Guest). - GabeU7 years agoDistinguished Professor IV
Please perform the following test outlined in the graphic below, though follow the full instructions written below the graphic. This is known as a modem isolation test, and it will help to determine whether the issue is with HughesNet or your local network..
Please be aware that, if you downloaded any large files just prior to this test, some usage may appear to have occurred due to the slight delay in the modem reporting the data usage to the server, but it should be rather negligible.
Do not unplug, power cycle or internally reboot the modem after the test has been run, as the reps need to be able to reconcile your modem data logs with what is shown in the screenshots. Any of those three things will wipe out those logs, rendering the test results moot. Only after the reps have responded with their findings should any of those three things be done.
If you don't know how to disable the WiFi in the HT2000W, please see "How do I manage my built-in WiFi modem?" in this PDF. Please be sure to click "Save Settings" after unchecking "SSID Enable" for each of the four tabs individually (2.4Ghz, then 2.4Ghz Guest, then 5Ghz, then 5Ghz Guest). - GabeU6 years agoDistinguished Professor IV
Please perform the following test outlined in the graphic below, though follow the full instructions written below the graphic. This is known as a Modem Isolation Test, and it will help to determine whether the issue is with HughesNet or your local network..
The screenshot should look similar to the following, being dependent on the operating system, with the clock included.
If you don't know how to disable the WiFi in the HT2000W modem, please see "How do I manage my built-in WiFi modem?" in this PDF. Please be sure to click "Save Settings" after unchecking "SSID Enable" for each of the four tabs individually (2.4Ghz, then 2.4Ghz Guest, then 5Ghz, then 5Ghz Guest). - GabeU6 years agoDistinguished Professor IV
2: Take a screenshot of the HughesNet Usage Meter, along with the clock on your computer screen.
6: Take a screenshot of the HughesNet Usage Meter, along with the clock displayed on your computer.
The screenshots should look similar to the following, being dependent on the operating system, with the system clock included (you can move the Usage Meter window to being near the system clock so that it is included more easily).
Please be aware that, if you downloaded any large files just prior to this test, some usage may appear to have occurred due to the slight delay (lag) in the modem reporting the data usage to the server, but it should be rather negligible.
To help the HughesNet Customer Service Reps get a head start on your speed concerns, please create a testmy.net account (if you do not already have one) and, while signed into that account, perform a batch of 3-5 tests during different parts of the day, then share your testmy.net "My Results" page URL with us here.
-if testing upload instead of download, use the manual 4MB size upload test file
2: Take a screenshot of the Home page of the System Control Center, along with the clock on your computer screen.
6: Take a screenshot of the Home page of the System Control Center, along with the clock on your computer screen.
The screenshots should look similar to the following, being dependent on the operating system, with the system clock included (you can move the System Control Center data level window to being near the system clock so that it is included more easily).
If you don't know how to disable the WiFi in the HT2000W, please see "How do I manage my built-in WiFi modem?" in this PDF. Please be sure to click "Save Settings" after unchecking "SSID Enable" for each of the four tabs individually (2.4Ghz, then 2.4Ghz Guest, then 5Ghz, then 5Ghz Guest). - maratsade6 years agoDistinguished Professor IV
If you don't know how to disable the WiFi in the HT2000W, please see "How do I manage my built-in WiFi modem?" in this PDF. Please be sure to click "Save Settings" after unchecking "SSID Enable" for each of the four tabs individually (2.4Ghz, then 2.4Ghz Guest, then 5Ghz, then 5Ghz Guest). - GabeU5 years agoDistinguished Professor IV
If you don't know how to disable the WiFi in the HT2000W modem, please see "How do I manage my built-in WiFi modem?" in this PDF. Please be sure to click "Save Settings" after unchecking "SSID Enable" for each of the four tabs individually (2.4Ghz, then 2.4Ghz Guest, then 5Ghz, then 5Ghz Guest). - maratsade5 years agoDistinguished Professor IV
