Speed test on Testmy
Working here. Nice result just now btw:
maratsade wrote:Doing very nicely here too.
And REALLY nicely on Nov 14th. :p
It's too bad you don't run any upload tests. If you ran a few, you'd be in the "Member Rank" for HughesNet speed tests on TMN, and with test results like that you'd probably be #1. :p
I know, right? I love those tests, when Testmy goes a little nutty.
I usually don't run upload tests because they're always between 2 and 3 Mbps (unless the connection is clogged, in which case it may be less). Testmy never gives me speed of light uploads; they just do it with downloads.
GabeU wrote:And REALLY nicely on Nov 14th. :p
