Using TestMy.net to compare your speed to others on your beam
MarkJFine wrote:Incidentally, latency is usually the real tell that congestion exists because it will show delayed packets in the buffer. A beam could becoming congested and you'd not know it from looking at speed until the congestion becomes extreme. Then it's not just speed, but dropped packets as well, just because the system can't keep up with the buffered requests/responses.
I agree -- if I download the log and graph the column of numbers behind the RTT flag, during normal week days for my beam it rises briefly at 2am, 3am, then rises 6:30am-7:30am, and does the big rise from 6:30pm to 11pm. The highest numbers usually are around 8:30pm. Other times it is at the minimum. This number appears to only include the time for the queueing up and ride over the satellite, as they have some other columns that look at the time past that. There is also a column for lost packets and %. If this number goes above 2000ms average for a 5 minute period, you get a red X on the 5 minute chart. If the 5 minute chart records 2 Xs (or maybe 3?) it gives a red X on the hourly chart -- simple and useful, I thought.
But while this seems to give some insight about my own beam and how busy it is at different times a day, it does not tell me anything about your beam.
If I was moving or considering Hughesnet, I think this gives me some idea what it is like around beam 68 recently. If this is way off from your expectation and experience, please do let me know. This score is not too shabby! This score looks decent since a bunch of these tests would have been run from phones over 2.4Ghz WiFi with small test blocks that lower the average!
Now on the other hand, if we find that 40 of these 109 tests were run from a beam in Idaho, and that the people shown here are not in beam 68, then this tells us very little.
I am running some more tests on my beam to see how much "salting" of the beam I can do since I am pulling around 50Mbps at the moment....
Your data sounds about right:
More and more people are making use of the Bonus period to do heavy lifting (sofware updates, etc.). The ones you see at 0230 are likely automated while people are sleeping, and the ones at 0630 are likely manual as people are getting up. I personally do all mine at 0500 to beat the 0630-0700 rush hour.
I'd be willing to bet the evening rise actually starts around 1630 and continues to ramp to a frenzy between 20-2100, then becomes normal again between 22-2300. That's always been the trend, and almost always when people are trying to stream something.
Streaming always puts the biggest load on the system because of the number and consistency of the packets, as well as the potential need for unecessary resends due to the delays in a streaming server getting an ack that a segment was received correctly, and in the proper sequence. It puts a tremendous load on system resources, which is not good when resources are limited.
In a situation where latency increases with congestion, all these people that say they keep getting buffering yet continue to let it keep loading, playing, and buffering just make it worse. It's like holding a mic to a 1,000w amp speaker and wondering why the feedback just keeps getting louder and more intense until it can't take anymore and it just clips. Repeated buffering is the system's way of telling them "this isn't working, you're killing me, please stop" but they don't get the hint because god forbid they miss their Netfilix show, so everyone on the beam and ultimately the gateway suffers. Then they blame the network for something they did (Modern entitlement problems). </soapbox>
- MrBuster6 years agoSenior
As anyone that has followed the thread above may have noticed, there is a button to display the data behind the median and average shown. So you can review the individual test results and copy them to exclude the suspicious results created by miscreants, nefarious individuals, dirty birds, or friendly flounder that may have been engaged in salting the beam with wild scores for fun or profit.
Ah! Netflix time! Personally, I like buffering because birds are incontinent by nature and I can use the breaks, so prime time here I come! HD
MrBuster wrote:So you can review the individual test results and copy them to exclude the suspicious results created by miscreants, nefarious individuals, dirty birds, or friendly flounder that may have been engaged in salting the beam with wild scores for fun or profit.
Or the more likely reason, which is a legitimately faulty test and result, which many HughesNet subscribers who use testmy.net on a regular basis will eventually see. I've had them myself, and when they happen I always delete them.
Occam's razor.
GabeU wrote:Or the more likely reason, which is a legitimately faulty test and result, which many HughesNet subscribers who use testmy.net on a regular basis will eventually see. I've had them myself, and when they happen I always delete them.
The comment about suspicious results was related to the laugh we had about the idea of running a bunch of tests at 4am to "salt the beam" to make it look good, but the point of faulty test runs is a fair point. In looking at results, it seems that wrong test size is far more likely to be something to filter out.
Anyway, the idea is that it is possible to compare your test results with others in your area with the caveat that some users may be on J1, and so a different beam. In looking at the cities associated with my results, the majority are relatively close to the beam center, and so it promised little overlap with a J1 beam, but with the numbers that maratsade gave, it is obvious there is a high probability that users from J1 and J2 will be listed in the data of a single city.
On the good side, glancing around numerous cities along the east coast gives a demonstration that the majority of customers have good performance since the average score is often 25Mbps to 35Mbps even with the test result records with incorrect small test sizes included. This means the good test results I am seeing are not unusual.
Having a way to show objective evidence that other users in an area are having decent performance can help to rule out that the problem is at the gateway or with the beam. Poor scores in an area do not prove anything, but do not exclude anything either.
How often have you seen somebody proclaim that the problem is with beam or the gateway? As users without any inside information regarding the system there is no way to say. With the TestMy.net database, when a user has an issue and presents a TestMy.net record, it is possible to compare the results with other user's test results in the area potentially providing some demonstration of what the problem is NOT, and helping with the process of troubleshooting.
Do you not see any value in that?
"The comment about suspicious results was related to the laugh we had about the idea of running a bunch of tests at 4am to "salt the beam" to make it look good"
This task has been assigned to you, Agent B. How are you doing with this? ;)
MrBuster wrote:How often have you seen somebody proclaim that the problem is with beam or the gateway? As users without any inside information regarding the system there is no way to say. With the TestMy.net database, when a user has an issue and presents a TestMy.net record, it is possible to compare the results with other user's test results in the area potentially providing some demonstration of what the problem is NOT, and helping with the process of troubleshooting.
I can see some value in it, but to be honest, not a lot as it is, and here's why I say this...
1. The locations at testmy.net are too inconsistent. For individuals, the locations chosen may be in their actual beam area at some times, but not at others, and the converse is true, as in others who are not in a specific beam area being linked to locations which are.
2. Many areas have multiple beams covering them, including those by both Jupiter satellites (ES17 and ES19). As well, there are likely a few "stragglers" still on the older satellite(s) with daily refill plans, which could skew the area results even further when it comes to the information being gleaned from the "local" tests.
3. Beams assigned to a specific gateway can affect the performance of the other beams assigned to the same, skewing what an individual beam might actually be capable of at a given time, which could fluctuate from one moment to the next.
Again, though I can see value in it, to get a realistic, even somewhat accurate idea of what each beam is doing, it would require significant participation, and with more info than testmy.net itself can provide.
Something I think I need to point out:
The testing done on TestMy will only show something particular to that beam when people using the same beam get like results at the same time, but those on other beams using the same gateway get something different. That would prove there's something that's specific to just that particular beam.If all beams on a gateway have the same symptoms at the same time it might mean there is a problem with the gateway, but it's not definite. It could also mean there's a problem anywhere between the gateway and the TestMy server, since they'd all likely be using the same route.
A good example was the widespread outage that CenturyLink had a few weeks ago, which affected the San Diego gateway. Think you'll find this kind of thing is a lot more common than the gateway going down.
Good points all.
I was just looking for the case where all descent tests by all users associated with a city scored well, as that implies no problem within some recent time period.
Considering two threads (titles in bold below are the threads):
Slow speed
In looking at a city for the user, I could see that all test results were bad. Of course a huge number of the tests used a test size that was far too small, and thus would give a bad score because the latency "put a thumb" on the scale so to speak. Nothing here to say what the problem is, or if there really is a problem -- but it does not say it is good either. The engineers did something and performance improved for multiple customers.
Slow internet speed
In looking at a city for this user, I saw other users with good scores at the same time this user had low scores. Of course it could be a J1 beam vs J2 beam thing, but the results hinted that this is not an issue everyone is facing. In the end, it appears that the issue was that "multithreading" was turned on. In looking in the history, the users tests were good before this feature was turned on, so the multithreading test may have been the issue.
Perhaps a Big Chungus was lodged in the Level 3 pipes between one of the servers used for the multithread test and the gateway causing the whole test score to look bad. :-)
Recently, I have been seeing really good speeds. In fact, I was thinking they were unusually good. Of course, I mostly just watch the latency as it is an unobtrusive way to have an idea of how busy things are without running a testmy -- kind of like guessing at how many people are in the store by tracking your average wait time at a grocery checkout.
And things have seemed empty, so I figured I would run a bunch of testmy in prime time which I don't normally do because I don't like the idea of wasting bandwidth when it is most in demand. The results look like they came from 4am -- this beam feels empty, like right after I first was installed in 2017, and again right after that first gateway upgrade in 2017 that doubled the IPGW that were showing up. I had other testmy result recently that were very good, but as they were run in less busy times, I figured it was not that unusual. In looking at TestMy scores for cities that I have a been associated with, I see a bunch of bad scores that have dragged the averages down on the recent tests list. Of course, many of these used the wrong test size but maybe TestMy backed the test size down since they were around 1Mbps?
There is a fellow reporting speed issues, and in his early tests, I noticed he was associated with a city at the southern edge of my beam according to SatBeams, but I figured that SatBeams is probably off a bit for the beam placement, and the location data is probably only crudely lining up with the beam, so he could be on a beam to the south. In more recent tests, the location data gave a city at the northern edge of my beam, so unless this location data is crazy off at times, it seems there is a fair chance he is on the same beam as me.
Also, I noticed his tests show remarkably consistent speed throughout the test, usually considered to be a sign of low congestion.
If he is in my beam, could other people on this beam be seeing the same thing he is? If so, could the high speeds I am seeing be the result of a group of other users on the beam being slowed way down by something? Could the rash of new testmy results with low scores at cities I have been associated with in the past be related?
I am showing J2CHY082HNSIGW1204 and have had this since 10/11 with OutRoute 4. I noticed my good speed some days later about the time the fellow posted about his low speed. I have seen in the past cases on this site where users report consistently bad speeds, then something happens and they are restored. Could a gateway server that handles a group of customers on the beam just need a reboot or something?
For you long time satellite users that have seen this before, was the resolution something along these lines? On the flip side, have you ever had a period of a week or so where the speed is insanely good?
What do you think? Of course, there is a lot of guessing here, but with some communication some light might be shed on what is going on.
I've had this 'conspiracy theory' that whenever the beam takes a sharp decline in performance, there's possibly always one (or two) recently added people to the beam that's bringing it down for everyone. One possibility is the person doesn't realize they're causing their own problem and discontinues, so the beam frees up.
Another possibility is the person was new, in their initial 20-day period, and didn't realize they were consistently dragging it down until they finally hit the Fair Access Policy. Whatever was causing the problem for everyone was therefore relieved.
If the problem was consistent enough, it was likely something like a constantly running HD security camera - usually something that takes a lot of resources and the person wouldn't even think twice about until it finally no longer worked.
Of course this is all supposition on my part, but have seen it happen often enough. Performance comes and goes. To be honest, it's probably a lot simpler explanation like the network periodically adjusting the load. - maratsade6 years agoDistinguished Professor IV
Occam's razor.
maratsade wrote:To be honest, it's probably a lot simpler explanation like the network periodically adjusting the load.
Occam's razor.
Yes, excellent point about the load balancing! Although I don't know much about how this works, it seems that the bandwidth of the beam (at least for download) is divided among the "Out Routes". I noticed that not only has my IPGW not changed since the 11th, neither has my outroute, and I think that normally changes fairly often, like every day or two at some seemingly random time. So maybe something that does the load balancing has stopped working on my beam and people who reboot are getting crowded onto a busy out route, while out route 4 becomes increasingly empty! I was going to reboot my modem last night, but held off when I began to suspect something -- even though my evidence is flimsy at best.
I could reboot tonight and see what happens -- but if this wild hypothesis about load balancing is remotely correct and I end up on a crowded out route then I will be very sad :-(
Of course, maybe the fantastic performance I am seeing is just the result of the great crush of traffic from the pandemic being over and I am finally seeing the result of those gateway upgrades they appear to have rolled out earlier this year. Although the speed tests I ran last night in prime time were eye popping, it was Saturday evening, so things are a little different for Saturday. Sunday usually appears to have more activity in the afternoon, so maybe I can retest then to see what happens.
We could also ask that fellow with the issue for his beam, IPGW, and out route to see if there is anything even remotely lining up, after all, if he is in Utah then there can not be anything here right?
So if we ask the fellow with the issue for beam/IPGW/out route, and he is on my beam with a different out route, and I see crazy high benchmarks consistently over 50Mbps again this afternoon which is usually fairly busy on a Sunday, and if I reboot to find myself in purgatory at 7pm tonight, then maybe there is something to this load balancing idea?
If the first two look to be true, I might not have the courage to reboot though.... :-)
What do you think?
Rebooting always pops you into a lesser used IPGW. It will also have the benefit of refreshing the DNS cache, which is always good. Sometimes that thing gets corrupted. I usually end up rebooting at least once a week, because my wife likes to work downstairs, away from the modem, which doesn't always have a good wifi signal. That's usually a good formula for a busted DNS cache.
Yes, exactly -- but if that process quit working for a bit it might be a problem as on reboot people might begin to accumulate on one IPGW. There may be a similar process with Out Route?
Anyway, from his testing, I see a third city show up that is 140 miles from the approximate beam 82 center. With my testmy results, the locations were within 60 miles of beam center 2/3 of the time, and the rest were within 90 miles. Maratsade had a larger distance, but with 140 miles (and that is if he is actually beam 82, so maybe the location data is even worse than this!) then maybe test scores are not just mixed in with J1 beams, but also neighboring J2 beams.
Also, I have been running test this afternoon, and they are not above 50Mbps, but looking good in the high 30's to mid 40's, so it is beginning to appear there is nothing to this and that I just had a streak of really high tests for a bit.
I also do a regular reboot, the early patches would get squirrelly after a week, but they seem a bit better now, so I try to reboot every two weeks. I don't think I need to worry about rebooting this evening and finding myself in slow-ville.
Do you think I should ask the fellow to confirm his beam/IPGW/Out route? I don't want to waste his time with a wild goose chase.
Can always see if the guy will respond.
I had noticed a few days ago that TestMy was showing an average test score for many towns in my beam that had dropped a lot in the last few weeks, and I thought maybe something was up, since it would take a lot of bad tests to cause the average to drop so much for the towns I was watching.
I pulled the list for several towns, and copied it out to a spreadsheet and filtered it down and I am seeing averages for each town much closer to the average numbers that I thought TestMy showed a few week ago. Other areas seems to show averages similar to what they had before, so maybe it is better to not rely on the average they show, and just pull the list out to see if things are still good for the region in general using a spreadsheet. A bit of a pain as it is easy to watch a group of towns by saving a direct link to each page, and takes a couple minutes to copy to a spreadsheet to verify the numbers....
My test scores are still high, but at least the low averages in the towns with my results do not appear to be caused by many low scores showing up recently and it appears rather than being a newly cropped up issue with the beam or gateway, that something changed with the way TestMy calculated the average in these towns.
Maybe TestMy excludes scores from the Town/ISP specific average they think are too high, and something happened to exclude a bunch of the better scores for Hughes in my area? Maybe "recent" changed to include everything in history?
