I was poking around the 'TestMy.net Database' option under 'DB' on the TestMy.net page, and I noticed something that might be useful for knowing how your tests compare with other users of HughesNet that share your beam -- and thus experience the same \"congestion\" circumstances that you do.
After you select 'TestMy.net Database', there is a list of details that they use to ID you -- this includes a city. As a satellite beam covers a wide area, the city I saw was some distance from me, but it appeared to be close to the center of my beam!
Click the City, then click the ISPs tab, and check to if you see a speed average for HughesNet for this city which may represent the average speed for your beam.
Would someone else try this and report what city you are seeing associated with your location along with your satellite beam number? This will let me know if this idea actually holds water so to speak. I have searched for others cities that I thought might be near a beam center and found some that I thought would be for Jupiter 1, VS1, and VS2 that appear to give speeds that are in the general range of what I guessed for each.
Does anyone familiar with TestMy.net know how to search a provider for cities that they have records for? That would make it a lot easier to check if this is an idea with potential or just nonsense as the cities I found with records have been found with just wild guessing based on looking at a map.
Now, of course, many folks that run the test use the wrong test size (too small test size and the test result is dominated by the start up time due to latency), or they are using Wi-Fi, so the average result numbers are likely to be on the low side, but if this works, then this would give a way to know if you are experiencing performance on-par with others that share your beam.
","kudosSumWeight":0,"postTime":"2020-10-03T18:24:17.109-04:00","images":{"__typename":"AssociatedImageConnection","edges":[],"totalCount":0,"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"attachments":{"__typename":"AttachmentConnection","pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null},"edges":[]},"tags":{"__typename":"TagConnection","pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null},"edges":[{"__typename":"TagEdge","cursor":"MjUuMnwyLjF8b3wxMHxfTlZffDE","node":{"__typename":"Tag","id":"tag:general discussion is not a support area","text":"general discussion is not a support area","time":"2018-09-10T13:02:20.678-04:00","lastActivityTime":null,"messagesCount":null,"followersCount":null}},{"__typename":"TagEdge","cursor":"MjUuMnwyLjF8b3wxMHxfTlZffDI","node":{"__typename":"Tag","id":"tag:testmy","text":"testmy","time":"2019-04-18T15:32:37.896-04:00","lastActivityTime":null,"messagesCount":null,"followersCount":null}}]},"timeToRead":2,"currentRevision":{"__ref":"Revision:revision:127931_1"},"latestVersion":null,"metrics":{"__typename":"MessageMetrics","views":14759},"visibilityScope":"PUBLIC","canonicalUrl":null,"seoTitle":null,"seoDescription":null,"isEscalated":null,"placeholder":false,"originalMessageForPlaceholder":null,"messagePolicies":{"__typename":"MessagePolicies","canModerateSpamMessage":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.feature.moderation_spam.action.moderate_entity.allowed.accessDenied","key":"error.lithium.policies.feature.moderation_spam.action.moderate_entity.allowed.accessDenied","args":[]}}},"archivalData":null,"customFields":[]},"Conversation:conversation:127931":{"__typename":"Conversation","id":"conversation:127931","solved":false,"topic":{"__ref":"ForumTopicMessage:message:127931"},"lastPostingActivityTime":"2020-10-27T17:24:54.293-04:00","lastPostTime":"2020-10-27T17:24:54.293-04:00","unreadReplyCount":37,"isSubscribed":false},"ModerationData:moderation_data:127931":{"__typename":"ModerationData","id":"moderation_data:127931","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"Revision:revision:127931_1":{"__typename":"Revision","id":"revision:127931_1","lastEditTime":"2020-10-03T18:24:17.109-04:00"},"ForumReplyMessage:message:128620":{"__typename":"ForumReplyMessage","id":"message:128620","conversation":{"__ref":"Conversation:conversation:127931"},"author":{"__ref":"User:user:12376"},"revisionNum":1,"uid":128620,"depth":18,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:General"},"subject":"Re: Using TestMy.net to compare your speed to others on your beam","readOnly":false,"editFrozen":false,"moderationData":{"__ref":"ModerationData:moderation_data:128620"},"parent":{"__ref":"ForumReplyMessage:message:128607"},"body":"
Rebooting always pops you into a lesser used IPGW. It will also have the benefit of refreshing the DNS cache, which is always good. Sometimes that thing gets corrupted. I usually end up rebooting at least once a week, because my wife likes to work downstairs, away from the modem, which doesn't always have a good wifi signal. That's usually a good formula for a busted DNS cache.
","body@stringLength":"387","rawBody":"Rebooting always pops you into a lesser used IPGW. It will also have the benefit of refreshing the DNS cache, which is always good. Sometimes that thing gets corrupted. I usually end up rebooting at least once a week, because my wife likes to work downstairs, away from the modem, which doesn't always have a good wifi signal. That's usually a good formula for a busted DNS cache.
","kudosSumWeight":1,"repliesCount":2,"postTime":"2020-10-25T13:55:50.254-04:00","images":{"__typename":"AssociatedImageConnection","edges":[],"totalCount":0,"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"attachments":{"__typename":"AttachmentConnection","pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null},"edges":[]},"timeToRead":1,"currentRevision":{"__ref":"Revision:revision:128620_1"},"latestVersion":null,"metrics":{"__typename":"MessageMetrics","views":8011},"visibilityScope":"PUBLIC","isEscalated":null,"placeholder":false,"originalMessageForPlaceholder":null,"messagePolicies":{"__typename":"MessagePolicies","canModerateSpamMessage":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.feature.moderation_spam.action.moderate_entity.allowed.accessDenied","key":"error.lithium.policies.feature.moderation_spam.action.moderate_entity.allowed.accessDenied","args":[]}}},"customFields":[],"descendants":{"__typename":"MessageConnection","edges":[{"__typename":"MessageEdge","cursor":"MjUuMnwyLjF8aXwyNXwzOToxfGludCwxMjg2MjIsMTI4NjIy","node":{"__ref":"ForumReplyMessage:message:128622"}},{"__typename":"MessageEdge","cursor":"MjUuMnwyLjF8aXwyNXwzOToxfGludCwxMjg2MjIsMTI4NjIz","node":{"__ref":"ForumReplyMessage:message:128623"}}],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}}},"CachedAsset:theme:customTheme1-1742463360362":{"__typename":"CachedAsset","id":"theme:customTheme1-1742463360362","value":{"id":"customTheme1","animation":{"fast":"150ms","normal":"250ms","slow":"500ms","slowest":"750ms","function":"cubic-bezier(0.07, 0.91, 0.51, 1)","__typename":"AnimationThemeSettings"},"avatar":{"borderRadius":"50%","collections":["default"],"__typename":"AvatarThemeSettings"},"basics":{"browserIcon":{"imageAssetName":"rebrand-favicon-1721032736485.png","imageLastModified":"1721032741408","__typename":"ThemeAsset"},"customerLogo":{"imageAssetName":"HughesnetLogo-1721027846492.png","imageLastModified":"1721027849927","__typename":"ThemeAsset"},"maximumWidthOfPageContent":"1200px","oneColumnNarrowWidth":"800px","gridGutterWidthMd":"30px","gridGutterWidthXs":"10px","pageWidthStyle":"WIDTH_OF_BROWSER","__typename":"BasicsThemeSettings"},"buttons":{"borderRadiusSm":"100vw","borderRadius":"100vw","borderRadiusLg":"100vw","paddingY":"5px","paddingYLg":"7px","paddingYHero":"var(--lia-bs-btn-padding-y-lg)","paddingX":"22px","paddingXLg":"24px","paddingXHero":"56px","fontStyle":"NORMAL","fontWeight":"400","textTransform":"NONE","disabledOpacity":0.5,"primaryTextColor":"var(--lia-bs-white)","primaryTextHoverColor":"var(--lia-bs-white)","primaryTextActiveColor":"var(--lia-bs-white)","primaryBgColor":"var(--lia-bs-primary)","primaryBgHoverColor":"hsl(var(--lia-bs-primary-h), var(--lia-bs-primary-s), calc(var(--lia-bs-primary-l) * 0.85))","primaryBgActiveColor":"hsl(var(--lia-bs-primary-h), var(--lia-bs-primary-s), calc(var(--lia-bs-primary-l) * 0.7))","primaryBorder":"1px solid transparent","primaryBorderHover":"1px solid transparent","primaryBorderActive":"1px solid transparent","primaryBorderFocus":"1px solid var(--lia-bs-white)","primaryBoxShadowFocus":"0 0 0 1px var(--lia-bs-primary), 0 0 0 4px hsla(var(--lia-bs-primary-h), var(--lia-bs-primary-s), var(--lia-bs-primary-l), 0.2)","secondaryTextColor":"var(--lia-bs-gray-900)","secondaryTextHoverColor":"hsl(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), calc(var(--lia-bs-gray-900-l) * 0.95))","secondaryTextActiveColor":"hsl(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), calc(var(--lia-bs-gray-900-l) * 0.9))","secondaryBgColor":"var(--lia-bs-gray-200)","secondaryBgHoverColor":"hsl(var(--lia-bs-gray-200-h), var(--lia-bs-gray-200-s), calc(var(--lia-bs-gray-200-l) * 0.96))","secondaryBgActiveColor":"hsl(var(--lia-bs-gray-200-h), var(--lia-bs-gray-200-s), calc(var(--lia-bs-gray-200-l) * 0.92))","secondaryBorder":"1px solid transparent","secondaryBorderHover":"1px solid transparent","secondaryBorderActive":"1px solid transparent","secondaryBorderFocus":"1px solid transparent","secondaryBoxShadowFocus":"0 0 0 1px var(--lia-bs-primary), 0 0 0 4px hsla(var(--lia-bs-primary-h), var(--lia-bs-primary-s), var(--lia-bs-primary-l), 0.2)","tertiaryTextColor":"var(--lia-bs-gray-900)","tertiaryTextHoverColor":"hsl(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), calc(var(--lia-bs-gray-900-l) * 0.95))","tertiaryTextActiveColor":"hsl(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), calc(var(--lia-bs-gray-900-l) * 0.9))","tertiaryBgColor":"transparent","tertiaryBgHoverColor":"transparent","tertiaryBgActiveColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.04)","tertiaryBorder":"1px solid transparent","tertiaryBorderHover":"1px solid hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.08)","tertiaryBorderActive":"1px solid transparent","tertiaryBorderFocus":"1px solid transparent","tertiaryBoxShadowFocus":"0 0 0 1px var(--lia-bs-primary), 0 0 0 4px hsla(var(--lia-bs-primary-h), var(--lia-bs-primary-s), var(--lia-bs-primary-l), 0.2)","destructiveTextColor":"var(--lia-bs-danger)","destructiveTextHoverColor":"hsl(var(--lia-bs-danger-h), var(--lia-bs-danger-s), calc(var(--lia-bs-danger-l) * 0.95))","destructiveTextActiveColor":"hsl(var(--lia-bs-danger-h), var(--lia-bs-danger-s), calc(var(--lia-bs-danger-l) * 0.9))","destructiveBgColor":"var(--lia-bs-gray-200)","destructiveBgHoverColor":"hsl(var(--lia-bs-gray-200-h), var(--lia-bs-gray-200-s), calc(var(--lia-bs-gray-200-l) * 0.96))","destructiveBgActiveColor":"hsl(var(--lia-bs-gray-200-h), var(--lia-bs-gray-200-s), calc(var(--lia-bs-gray-200-l) * 0.92))","destructiveBorder":"1px solid transparent","destructiveBorderHover":"1px solid transparent","destructiveBorderActive":"1px solid transparent","destructiveBorderFocus":"1px solid transparent","destructiveBoxShadowFocus":"0 0 0 1px var(--lia-bs-primary), 0 0 0 4px hsla(var(--lia-bs-primary-h), var(--lia-bs-primary-s), var(--lia-bs-primary-l), 0.2)","__typename":"ButtonsThemeSettings"},"border":{"color":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.08)","mainContent":"DARK","sideContent":"DARK","radiusSm":"3px","radius":"5px","radiusLg":"9px","radius50":"100vw","__typename":"BorderThemeSettings"},"boxShadow":{"xs":"0 0 0 1px hsla(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), var(--lia-bs-gray-900-l), 0.08), 0 3px 0 -1px hsla(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), var(--lia-bs-gray-900-l), 0.16)","sm":"0 2px 4px hsla(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), var(--lia-bs-gray-900-l), 0.12)","md":"0 5px 15px hsla(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), var(--lia-bs-gray-900-l), 0.3)","lg":"0 10px 30px hsla(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), var(--lia-bs-gray-900-l), 0.3)","__typename":"BoxShadowThemeSettings"},"cards":{"bgColor":"var(--lia-panel-bg-color)","borderRadius":"var(--lia-panel-border-radius)","boxShadow":"var(--lia-box-shadow-xs)","__typename":"CardsThemeSettings"},"chip":{"maxWidth":"300px","height":"30px","__typename":"ChipThemeSettings"},"coreTypes":{"defaultMessageLinkColor":"#005DAC","defaultMessageLinkDecoration":"none","defaultMessageLinkFontStyle":"NORMAL","defaultMessageLinkFontWeight":"400","defaultMessageFontStyle":"NORMAL","defaultMessageFontWeight":"400","forumColor":"#4099E2","forumFontFamily":"var(--lia-bs-font-family-base)","forumFontWeight":"var(--lia-default-message-font-weight)","forumLineHeight":"var(--lia-bs-line-height-base)","forumFontStyle":"var(--lia-default-message-font-style)","forumMessageLinkColor":"var(--lia-default-message-link-color)","forumMessageLinkDecoration":"var(--lia-default-message-link-decoration)","forumMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","forumMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","forumSolvedColor":"#148563","blogColor":"#1CBAA0","blogFontFamily":"var(--lia-bs-font-family-base)","blogFontWeight":"var(--lia-default-message-font-weight)","blogLineHeight":"1.75","blogFontStyle":"var(--lia-default-message-font-style)","blogMessageLinkColor":"var(--lia-default-message-link-color)","blogMessageLinkDecoration":"var(--lia-default-message-link-decoration)","blogMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","blogMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","tkbColor":"#4C6B90","tkbFontFamily":"var(--lia-bs-font-family-base)","tkbFontWeight":"var(--lia-default-message-font-weight)","tkbLineHeight":"1.75","tkbFontStyle":"var(--lia-default-message-font-style)","tkbMessageLinkColor":"var(--lia-default-message-link-color)","tkbMessageLinkDecoration":"var(--lia-default-message-link-decoration)","tkbMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","tkbMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","qandaColor":"#4099E2","qandaFontFamily":"var(--lia-bs-font-family-base)","qandaFontWeight":"var(--lia-default-message-font-weight)","qandaLineHeight":"var(--lia-bs-line-height-base)","qandaFontStyle":"var(--lia-default-message-link-font-style)","qandaMessageLinkColor":"var(--lia-default-message-link-color)","qandaMessageLinkDecoration":"var(--lia-default-message-link-decoration)","qandaMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","qandaMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","qandaSolvedColor":"#3FA023","ideaColor":"#FF8000","ideaFontFamily":"var(--lia-bs-font-family-base)","ideaFontWeight":"var(--lia-default-message-font-weight)","ideaLineHeight":"var(--lia-bs-line-height-base)","ideaFontStyle":"var(--lia-default-message-font-style)","ideaMessageLinkColor":"var(--lia-default-message-link-color)","ideaMessageLinkDecoration":"var(--lia-default-message-link-decoration)","ideaMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","ideaMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","contestColor":"#FCC845","contestFontFamily":"var(--lia-bs-font-family-base)","contestFontWeight":"var(--lia-default-message-font-weight)","contestLineHeight":"var(--lia-bs-line-height-base)","contestFontStyle":"var(--lia-default-message-link-font-style)","contestMessageLinkColor":"var(--lia-default-message-link-color)","contestMessageLinkDecoration":"var(--lia-default-message-link-decoration)","contestMessageLinkFontStyle":"ITALIC","contestMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","occasionColor":"#D13A1F","occasionFontFamily":"var(--lia-bs-font-family-base)","occasionFontWeight":"var(--lia-default-message-font-weight)","occasionLineHeight":"var(--lia-bs-line-height-base)","occasionFontStyle":"var(--lia-default-message-font-style)","occasionMessageLinkColor":"var(--lia-default-message-link-color)","occasionMessageLinkDecoration":"var(--lia-default-message-link-decoration)","occasionMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","occasionMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","grouphubColor":"#333333","categoryColor":"#949494","communityColor":"#FFFFFF","productColor":"#949494","__typename":"CoreTypesThemeSettings"},"colors":{"black":"#000000","white":"#FFFFFF","gray100":"#F7F7F7","gray200":"#F7F7F7","gray300":"#E8E8E8","gray400":"#D9D9D9","gray500":"#CCCCCC","gray600":"#949494","gray700":"#707070","gray800":"#545454","gray900":"#333333","dark":"#545454","light":"#F7F7F7","primary":"#005DAC","secondary":"#333333","bodyText":"#000000","bodyBg":"#F7F7F8","info":"#409AE2","success":"#41C5AE","warning":"#FCB116","danger":"#DE3700","alertSystem":"#FF6600","textMuted":"#707070","highlight":"#FFFCAD","outline":"var(--lia-bs-primary)","custom":["#00223A","#0096FA","#0E4275","#005DAC","#1C475A","#00223A","#0E4275","#FF0000","#0099AA","#582596","#660099","#0000FF","#0066FF","#006600","#009900","#00CC00","#33CC00"],"__typename":"ColorsThemeSettings"},"divider":{"size":"3px","marginLeft":"4px","marginRight":"4px","borderRadius":"50%","bgColor":"var(--lia-bs-gray-600)","bgColorActive":"var(--lia-bs-gray-600)","__typename":"DividerThemeSettings"},"dropdown":{"fontSize":"var(--lia-bs-font-size-sm)","borderColor":"var(--lia-bs-border-color)","borderRadius":"var(--lia-bs-border-radius-sm)","dividerBg":"var(--lia-bs-gray-300)","itemPaddingY":"5px","itemPaddingX":"20px","headerColor":"var(--lia-bs-gray-700)","__typename":"DropdownThemeSettings"},"email":null,"emoji":{"skinToneDefault":"#ffcd43","skinToneLight":"#fae3c5","skinToneMediumLight":"#e2cfa5","skinToneMedium":"#daa478","skinToneMediumDark":"#a78058","skinToneDark":"#5e4d43","__typename":"EmojiThemeSettings"},"heading":{"color":"var(--lia-bs-body-color)","fontFamily":"Montserrat","fontStyle":"NORMAL","fontWeight":"700","h1FontSize":"34px","h2FontSize":"28px","h3FontSize":"18px","h4FontSize":"18px","h5FontSize":"18px","h6FontSize":"18px","lineHeight":"1.3","subHeaderFontSize":"11px","subHeaderFontWeight":"500","h1LetterSpacing":"normal","h2LetterSpacing":"normal","h3LetterSpacing":"normal","h4LetterSpacing":"normal","h5LetterSpacing":"normal","h6LetterSpacing":"normal","subHeaderLetterSpacing":"2px","h1FontWeight":"var(--lia-bs-headings-font-weight)","h2FontWeight":"var(--lia-bs-headings-font-weight)","h3FontWeight":"var(--lia-bs-headings-font-weight)","h4FontWeight":"var(--lia-bs-headings-font-weight)","h5FontWeight":"var(--lia-bs-headings-font-weight)","h6FontWeight":"var(--lia-bs-headings-font-weight)","__typename":"HeadingThemeSettings"},"icons":{"size10":null,"size12":"12px","size14":"14px","size16":"16px","size20":"20px","size24":"24px","size30":"30px","size40":"40px","size50":"50px","size60":"60px","size80":"80px","size120":"120px","size160":"160px","__typename":"IconsThemeSettings"},"imagePreview":{"bgColor":"var(--lia-bs-gray-900)","titleColor":"var(--lia-bs-white)","controlColor":"var(--lia-bs-white)","controlBgColor":"var(--lia-bs-gray-800)","__typename":"ImagePreviewThemeSettings"},"input":{"borderColor":"var(--lia-bs-gray-600)","disabledColor":"var(--lia-bs-gray-600)","focusBorderColor":"var(--lia-bs-primary)","labelMarginBottom":"10px","btnFontSize":"var(--lia-bs-font-size-sm)","focusBoxShadow":"0 0 0 3px hsla(var(--lia-bs-primary-h), var(--lia-bs-primary-s), var(--lia-bs-primary-l), 0.2)","checkLabelMarginBottom":"2px","checkboxBorderRadius":"3px","borderRadiusSm":"100vw","borderRadius":"100vw","borderRadiusLg":"100vw","formTextMarginTop":"4px","textAreaBorderRadius":"20px","activeFillColor":"var(--lia-bs-primary)","__typename":"InputThemeSettings"},"loading":{"dotDarkColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.2)","dotLightColor":"hsla(var(--lia-bs-white-h), var(--lia-bs-white-s), var(--lia-bs-white-l), 0.5)","barDarkColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.06)","barLightColor":"hsla(var(--lia-bs-white-h), var(--lia-bs-white-s), var(--lia-bs-white-l), 0.4)","__typename":"LoadingThemeSettings"},"link":{"color":"var(--lia-bs-primary)","hoverColor":"hsl(var(--lia-bs-primary-h), var(--lia-bs-primary-s), calc(var(--lia-bs-primary-l) - 10%))","decoration":"none","hoverDecoration":"underline","__typename":"LinkThemeSettings"},"listGroup":{"itemPaddingY":"15px","itemPaddingX":"15px","borderColor":"var(--lia-bs-gray-300)","__typename":"ListGroupThemeSettings"},"modal":{"contentTextColor":"var(--lia-bs-body-color)","contentBg":"var(--lia-bs-white)","backgroundBg":"var(--lia-bs-black)","smSize":"440px","mdSize":"760px","lgSize":"1080px","backdropOpacity":0.3,"contentBoxShadowXs":"var(--lia-bs-box-shadow-sm)","contentBoxShadow":"var(--lia-bs-box-shadow)","headerFontWeight":"700","__typename":"ModalThemeSettings"},"navbar":{"position":"FIXED","background":{"attachment":null,"clip":null,"color":"var(--lia-bs-white)","imageAssetName":"","imageLastModified":"0","origin":null,"position":"CENTER_CENTER","repeat":"NO_REPEAT","size":"COVER","__typename":"BackgroundProps"},"backgroundOpacity":0.8,"paddingTop":"15px","paddingBottom":"15px","borderBottom":"1px solid var(--lia-bs-border-color)","boxShadow":"var(--lia-bs-box-shadow-sm)","brandMarginRight":"30px","brandMarginRightSm":"10px","brandLogoHeight":"30px","linkGap":"10px","linkJustifyContent":"flex-start","linkPaddingY":"5px","linkPaddingX":"10px","linkDropdownPaddingY":"9px","linkDropdownPaddingX":"var(--lia-nav-link-px)","linkColor":"var(--lia-bs-body-color)","linkHoverColor":"var(--lia-bs-primary)","linkFontSize":"var(--lia-bs-font-size-sm)","linkFontStyle":"NORMAL","linkFontWeight":"400","linkTextTransform":"NONE","linkLetterSpacing":"normal","linkBorderRadius":"var(--lia-bs-border-radius-sm)","linkBgColor":"transparent","linkBgHoverColor":"transparent","linkBorder":"none","linkBorderHover":"none","linkBoxShadow":"none","linkBoxShadowHover":"none","linkTextBorderBottom":"none","linkTextBorderBottomHover":"none","dropdownPaddingTop":"10px","dropdownPaddingBottom":"15px","dropdownPaddingX":"10px","dropdownMenuOffset":"2px","dropdownDividerMarginTop":"10px","dropdownDividerMarginBottom":"10px","dropdownBorderColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.08)","controllerBgHoverColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.1)","controllerIconColor":"var(--lia-bs-body-color)","controllerIconHoverColor":"var(--lia-bs-body-color)","controllerTextColor":"var(--lia-nav-controller-icon-color)","controllerTextHoverColor":"var(--lia-nav-controller-icon-hover-color)","controllerHighlightColor":"hsla(30, 100%, 50%)","controllerHighlightTextColor":"var(--lia-yiq-light)","controllerBorderRadius":"var(--lia-border-radius-50)","hamburgerColor":"var(--lia-nav-controller-icon-color)","hamburgerHoverColor":"var(--lia-nav-controller-icon-color)","hamburgerBgColor":"transparent","hamburgerBgHoverColor":"transparent","hamburgerBorder":"none","hamburgerBorderHover":"none","collapseMenuMarginLeft":"20px","collapseMenuDividerBg":"var(--lia-nav-link-color)","collapseMenuDividerOpacity":0.16,"__typename":"NavbarThemeSettings"},"pager":{"textColor":"var(--lia-bs-link-color)","textFontWeight":"var(--lia-font-weight-md)","textFontSize":"var(--lia-bs-font-size-sm)","__typename":"PagerThemeSettings"},"panel":{"bgColor":"var(--lia-bs-white)","borderRadius":"var(--lia-bs-border-radius)","borderColor":"var(--lia-bs-border-color)","boxShadow":"none","__typename":"PanelThemeSettings"},"popover":{"arrowHeight":"8px","arrowWidth":"16px","maxWidth":"300px","minWidth":"100px","headerBg":"var(--lia-bs-white)","borderColor":"var(--lia-bs-border-color)","borderRadius":"var(--lia-bs-border-radius)","boxShadow":"0 0.5rem 1rem hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.15)","__typename":"PopoverThemeSettings"},"prism":{"color":"#000000","bgColor":"#f5f2f0","fontFamily":"var(--font-family-monospace)","fontSize":"var(--lia-bs-font-size-base)","fontWeightBold":"var(--lia-bs-font-weight-bold)","fontStyleItalic":"italic","tabSize":2,"highlightColor":"#b3d4fc","commentColor":"#62707e","punctuationColor":"#6f6f6f","namespaceOpacity":"0.7","propColor":"#990055","selectorColor":"#517a00","operatorColor":"#906736","operatorBgColor":"hsla(0, 0%, 100%, 0.5)","keywordColor":"#0076a9","functionColor":"#d3284b","variableColor":"#c14700","__typename":"PrismThemeSettings"},"rte":{"bgColor":"var(--lia-bs-white)","borderRadius":"var(--lia-panel-border-radius)","boxShadow":" var(--lia-panel-box-shadow)","customColor1":"#bfedd2","customColor2":"#fbeeb8","customColor3":"#f8cac6","customColor4":"#eccafa","customColor5":"#c2e0f4","customColor6":"#2dc26b","customColor7":"#f1c40f","customColor8":"#e03e2d","customColor9":"#b96ad9","customColor10":"#3598db","customColor11":"#169179","customColor12":"#e67e23","customColor13":"#ba372a","customColor14":"#843fa1","customColor15":"#236fa1","customColor16":"#ecf0f1","customColor17":"#ced4d9","customColor18":"#95a5a6","customColor19":"#7e8c8d","customColor20":"#34495e","customColor21":"#000000","customColor22":"#ffffff","defaultMessageHeaderMarginTop":"15px","defaultMessageHeaderMarginBottom":"15px","defaultMessageItemMarginTop":"0","defaultMessageItemMarginBottom":"16px","diffAddedColor":"hsla(170, 53%, 51%, 0.4)","diffChangedColor":"hsla(43, 97%, 63%, 0.4)","diffNoneColor":"hsla(0, 0%, 80%, 0.4)","diffRemovedColor":"hsla(9, 74%, 47%, 0.4)","specialMessageHeaderMarginTop":"15px","specialMessageHeaderMarginBottom":"15px","specialMessageItemMarginTop":"0","specialMessageItemMarginBottom":"16px","__typename":"RteThemeSettings"},"tags":{"bgColor":"var(--lia-bs-gray-200)","bgHoverColor":"var(--lia-bs-gray-400)","borderRadius":"var(--lia-bs-border-radius-sm)","color":"var(--lia-bs-body-color)","hoverColor":"var(--lia-bs-body-color)","fontWeight":"var(--lia-font-weight-md)","fontSize":"var(--lia-font-size-xxs)","textTransform":"UPPERCASE","letterSpacing":"0.5px","__typename":"TagsThemeSettings"},"toasts":{"borderRadius":"var(--lia-bs-border-radius)","paddingX":"12px","__typename":"ToastsThemeSettings"},"typography":{"fontFamilyBase":"Source Sans Pro","fontStyleBase":"NORMAL","fontWeightBase":"400","fontWeightLight":"300","fontWeightNormal":"400","fontWeightMd":"500","fontWeightBold":"700","letterSpacingSm":"normal","letterSpacingXs":"normal","lineHeightBase":"1.5","fontSizeBase":"16px","fontSizeXxs":"11px","fontSizeXs":"14px","fontSizeSm":"15px","fontSizeLg":"20px","fontSizeXl":"24px","smallFontSize":"14px","customFonts":[{"source":"SERVER","name":"Axiforma-Regular","styles":[{"style":"NORMAL","weight":"400","__typename":"FontStyleData"}],"assetNames":["Axiforma-Regular-normal-400.woff2"],"__typename":"CustomFont"},{"source":"SERVER","name":"Source Sans Pro","styles":[{"style":"NORMAL","weight":"400","__typename":"FontStyleData"}],"assetNames":["SourceSansPro-normal-400.woff2"],"__typename":"CustomFont"}],"__typename":"TypographyThemeSettings"},"unstyledListItem":{"marginBottomSm":"5px","marginBottomMd":"10px","marginBottomLg":"15px","marginBottomXl":"20px","marginBottomXxl":"25px","__typename":"UnstyledListItemThemeSettings"},"yiq":{"light":"#ffffff","dark":"#000000","__typename":"YiqThemeSettings"},"colorLightness":{"primaryDark":0.36,"primaryLight":0.74,"primaryLighter":0.89,"primaryLightest":0.95,"infoDark":0.39,"infoLight":0.72,"infoLighter":0.85,"infoLightest":0.93,"successDark":0.24,"successLight":0.62,"successLighter":0.8,"successLightest":0.91,"warningDark":0.39,"warningLight":0.68,"warningLighter":0.84,"warningLightest":0.93,"dangerDark":0.41,"dangerLight":0.72,"dangerLighter":0.89,"dangerLightest":0.95,"__typename":"ColorLightnessThemeSettings"},"localOverride":false,"__typename":"Theme"},"localOverride":false},"CachedAsset:text:en_US-shared/client/components/common/Loading/LoadingDot-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/common/Loading/LoadingDot-1739990369000","value":{"title":"Loading..."},"localOverride":false},"CachedAsset:quilt:hughes.prod:pages/forums/ForumMessagePage:board:General-1742463358682":{"__typename":"CachedAsset","id":"quilt:hughes.prod:pages/forums/ForumMessagePage:board:General-1742463358682","value":{"id":"ForumMessagePage","container":{"id":"Common","headerProps":{"backgroundImageProps":null,"backgroundColor":null,"addComponents":null,"removeComponents":["community.widget.bannerWidget"],"componentOrder":null,"__typename":"QuiltContainerSectionProps"},"headerComponentProps":{"community.widget.breadcrumbWidget":{"disableLastCrumbForDesktop":false}},"footerProps":null,"footerComponentProps":null,"items":[{"id":"message-list","layout":"MAIN_SIDE","bgColor":null,"showTitle":null,"showDescription":null,"textPosition":null,"textColor":null,"sectionEditLevel":null,"bgImage":null,"disableSpacing":null,"edgeToEdgeDisplay":null,"fullHeight":null,"showBorder":null,"__typename":"MainSideQuiltSection","columnMap":{"main":[{"id":"messages.widget.topicWithThreadedReplyListWidget","className":"lia-topic-with-replies","props":{"editLevel":"CONFIGURE"},"__typename":"QuiltComponent"}],"side":[{"id":"messages.widget.relatedContentWidget","className":null,"props":null,"__typename":"QuiltComponent"},{"id":"messages.widget.messageListForNodeByRecentActivityWidget","className":null,"props":{"hideIfEmpty":true,"useTitle":true,"showTabs":false,"pageSize":5,"pagerVariant":{"type":"loadMore"},"style":"compact","viewVariant":{"type":"inline","props":{"useRepliesCount":false,"useMedia":false,"useAuthorRank":false,"useNode":false,"boardIconSize":"24","truncateBodyLength":-1,"useNodeLink":true,"usePreviewMedia":false,"timeStampType":"conversation.lastPostingActivityTime","avatarSize":"40","useTextBody":true,"useSolvedBadge":true,"subjectAs":"h6","renderPostTimeBeforeAuthor":true,"useAvatar":true,"useTimeToRead":false,"useSpoilerFreeBody":true,"useKudosCount":false,"useViewCount":false,"useBody":false,"useTags":false,"clampSubjectLines":1,"useBoardIcon":false,"useMessageTimeLink":true,"clampBodyLines":3,"useAuthorLogin":true,"useUnreadCount":false,"useNodeHoverCard":true,"useSearchSnippet":false}},"panelType":"divider","sorts":{"conversationLastPostingActivityTime":{"direction":"DESC"}}},"__typename":"QuiltComponent"},{"id":"custom.widget.MixPanelTracker","className":null,"props":{"widgetVisibility":"signedInOrAnonymous","useTitle":true,"useBackground":false,"title":"","lazyLoad":false},"__typename":"QuiltComponent"}],"__typename":"MainSideSectionColumns"}}],"__typename":"QuiltContainer"},"__typename":"Quilt","localOverride":false},"localOverride":false},"CachedAsset:text:en_US-components/common/EmailVerification-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-components/common/EmailVerification-1739990369000","value":{"email.verification.title":"Email Verification Required","email.verification.message.update.email":"To participate in the community, you must first verify your email address. The verification email was sent to {email}. To change your email, visit My Settings.","email.verification.message.resend.email":"To participate in the community, you must first verify your email address. The verification email was sent to {email}. Resend email."},"localOverride":false},"CachedAsset:text:en_US-pages/forums/ForumMessagePage-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-pages/forums/ForumMessagePage-1739990369000","value":{"title":"{contextMessageSubject} | {communityTitle}","errorMissing":"This message cannot be found","name":"Forum Message Page","section.message-list.title":"Forum Discussion","archivedMessageTitle":"This Content Has Been Archived"},"localOverride":false},"CachedAsset:quiltWrapper:hughes.prod:Common:1742463290066":{"__typename":"CachedAsset","id":"quiltWrapper:hughes.prod:Common:1742463290066","value":{"id":"Common","header":{"backgroundImageProps":{"assetName":null,"backgroundSize":"COVER","backgroundRepeat":"NO_REPEAT","backgroundPosition":"CENTER_CENTER","lastModified":null,"__typename":"BackgroundImageProps"},"backgroundColor":"transparent","items":[{"id":"community.widget.navbarWidget","props":{"showUserName":false,"showRegisterLink":true,"useIconLanguagePicker":true,"useLabelLanguagePicker":true,"links":{"sideLinks":[],"mainLinks":[]},"className":"QuiltComponent_lia-component-edit-mode__0nCcm","style":{"boxShadow":"var(--lia-bs-box-shadow-sm)","linkFontWeight":"400","controllerHighlightColor":"hsla(30, 100%, 50%)","dropdownDividerMarginBottom":"10px","hamburgerBorderHover":"none","linkFontSize":"15px","linkBoxShadowHover":"none","backgroundOpacity":0.8,"controllerBorderRadius":"var(--lia-border-radius-50)","hamburgerBgColor":"transparent","linkTextBorderBottom":"none","hamburgerColor":"var(--lia-nav-controller-icon-color)","brandLogoHeight":"46px","linkLetterSpacing":"normal","linkBgHoverColor":"transparent","collapseMenuDividerOpacity":0.16,"paddingBottom":"10px","dropdownPaddingBottom":"15px","dropdownMenuOffset":"2px","hamburgerBgHoverColor":"transparent","borderBottom":"1px solid var(--lia-bs-border-color)","hamburgerBorder":"none","dropdownPaddingX":"10px","brandMarginRightSm":"10px","linkBoxShadow":"none","linkJustifyContent":"center","linkColor":"var(--lia-bs-primary)","collapseMenuDividerBg":"var(--lia-nav-link-color)","dropdownPaddingTop":"10px","controllerTextColor":"var(--lia-nav-controller-icon-color)","controllerHighlightTextColor":"var(--lia-yiq-dark)","background":{"imageAssetName":"","color":"var(--lia-bs-white)","size":"COVER","repeat":"NO_REPEAT","position":"CENTER_CENTER","imageLastModified":""},"linkBorderRadius":"var(--lia-bs-border-radius-sm)","linkHoverColor":"var(--lia-bs-primary)","position":"FIXED","linkBorder":"none","linkTextBorderBottomHover":"0","brandMarginRight":"30px","hamburgerHoverColor":"var(--lia-nav-controller-icon-color)","linkBorderHover":"none","collapseMenuMarginLeft":"20px","linkFontStyle":"NORMAL","linkPaddingX":"10px","controllerTextHoverColor":"var(--lia-nav-controller-icon-hover-color)","paddingTop":"10px","linkPaddingY":"5px","linkTextTransform":"NONE","dropdownBorderColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.08)","controllerBgHoverColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.1)","linkDropdownPaddingX":"var(--lia-nav-link-px)","linkBgColor":"transparent","linkDropdownPaddingY":"9px","controllerIconColor":"var(--lia-bs-body-color)","dropdownDividerMarginTop":"10px","linkGap":"10px","controllerIconHoverColor":"var(--lia-bs-body-color)"},"showSearchIcon":true,"languagePickerStyle":"iconAndLabel"},"__typename":"QuiltComponent"},{"id":"community.widget.breadcrumbWidget","props":{"backgroundColor":"var(--lia-bs-body-bg)","linkHighlightColor":"var(--lia-bs-primary)","visualEffects":{"showBottomBorder":true},"linkTextColor":"var(--lia-bs-body-color)"},"__typename":"QuiltComponent"},{"id":"community.widget.bannerWidget","props":{"backgroundColor":"var(--lia-bs-primary)","visualEffects":{"showBottomBorder":true},"backgroundOpacity":100,"backgroundImageProps":{"backgroundSize":"COVER","backgroundPosition":"CENTER_CENTER","backgroundRepeat":"NO_REPEAT"},"fontColor":"var(--lia-bs-body-bg)"},"__typename":"QuiltComponent"},{"id":"custom.widget.GoogleTagTracker","props":{"widgetVisibility":"signedInOrAnonymous","useTitle":true,"cProp_gtag":"G-JZZW630G5D","useBackground":false,"title":"","lazyLoad":false,"widgetChooser":"custom.widget.GoogleTagTracker"},"__typename":"QuiltComponent"}],"__typename":"QuiltWrapperSection"},"footer":{"backgroundImageProps":{"assetName":null,"backgroundSize":"COVER","backgroundRepeat":"NO_REPEAT","backgroundPosition":"CENTER_CENTER","lastModified":null,"__typename":"BackgroundImageProps"},"backgroundColor":"#00223A","items":[{"id":"custom.widget.custom_Footer","props":{"widgetVisibility":"signedInOrAnonymous","useTitle":true,"useBackground":false,"title":"","lazyLoad":false},"__typename":"QuiltComponent"}],"__typename":"QuiltWrapperSection"},"__typename":"QuiltWrapper","localOverride":false},"localOverride":false},"CachedAsset:text:en_US-components/common/ActionFeedback-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-components/common/ActionFeedback-1739990369000","value":{"joinedGroupHub.title":"Welcome","joinedGroupHub.message":"You are now a member of this group and are subscribed to updates.","groupHubInviteNotFound.title":"Invitation Not Found","groupHubInviteNotFound.message":"Sorry, we could not find your invitation to the group. The owner may have canceled the invite.","groupHubNotFound.title":"Group Not Found","groupHubNotFound.message":"The grouphub you tried to join does not exist. It may have been deleted.","existingGroupHubMember.title":"Already Joined","existingGroupHubMember.message":"You are already a member of this group.","accountLocked.title":"Account Locked","accountLocked.message":"Your account has been locked due to multiple failed attempts. Try again in {lockoutTime} minutes.","editedGroupHub.title":"Changes Saved","editedGroupHub.message":"Your group has been updated.","leftGroupHub.title":"Goodbye","leftGroupHub.message":"You are no longer a member of this group and will not receive future updates.","deletedGroupHub.title":"Deleted","deletedGroupHub.message":"The group has been deleted.","groupHubCreated.title":"Group Created","groupHubCreated.message":"{groupHubName} is ready to use","accountClosed.title":"Account Closed","accountClosed.message":"The account has been closed and you will now be redirected to the homepage","resetTokenExpired.title":"Reset Password Link has Expired","resetTokenExpired.message":"Try resetting your password again","invalidUrl.title":"Invalid URL","invalidUrl.message":"The URL you're using is not recognized. Verify your URL and try again.","accountClosedForUser.title":"Account Closed","accountClosedForUser.message":"{userName}'s account is closed","inviteTokenInvalid.title":"Invitation Invalid","inviteTokenInvalid.message":"Your invitation to the community has been canceled or expired.","inviteTokenError.title":"Invitation Verification Failed","inviteTokenError.message":"The url you are utilizing is not recognized. Verify your URL and try again","pageNotFound.title":"Access Denied","pageNotFound.message":"You do not have access to this area of the community or it doesn't exist","eventAttending.title":"Responded as Attending","eventAttending.message":"You'll be notified when there's new activity and reminded as the event approaches","eventInterested.title":"Responded as Interested","eventInterested.message":"You'll be notified when there's new activity and reminded as the event approaches","eventNotFound.title":"Event Not Found","eventNotFound.message":"The event you tried to respond to does not exist.","redirectToRelatedPage.title":"Showing Related Content","redirectToRelatedPageForBaseUsers.title":"Showing Related Content","redirectToRelatedPageForBaseUsers.message":"The content you are trying to access is archived","redirectToRelatedPage.message":"The content you are trying to access is archived","relatedUrl.archivalLink.flyoutMessage":"The content you are trying to access is archived View Archived Content"},"localOverride":false},"CachedAsset:component:custom.widget.GoogleTagTracker-en-1742463372930":{"__typename":"CachedAsset","id":"component:custom.widget.GoogleTagTracker-en-1742463372930","value":{"component":{"id":"custom.widget.GoogleTagTracker","template":{"id":"GoogleTagTracker","markupLanguage":"HANDLEBARS","style":null,"texts":null,"defaults":{"config":{"applicablePages":[],"description":"Executes Google Tag tracking scripts","fetchedContent":null,"__typename":"ComponentConfiguration"},"props":[{"id":"prop_gtag","dataType":"STRING","list":false,"defaultValue":"","label":"Google Tag Manager Id","description":null,"possibleValues":null,"control":"INPUT","__typename":"PropDefinition"}],"__typename":"ComponentProperties"},"components":[{"id":"custom.widget.GoogleTagTracker","form":{"fields":[{"id":"widgetChooser","validation":null,"noValidation":null,"dataType":"STRING","list":null,"control":null,"defaultValue":null,"label":null,"description":null,"possibleValues":null,"__typename":"FormField"},{"id":"title","validation":null,"noValidation":null,"dataType":"STRING","list":null,"control":null,"defaultValue":null,"label":null,"description":null,"possibleValues":null,"__typename":"FormField"},{"id":"useTitle","validation":null,"noValidation":null,"dataType":"BOOLEAN","list":null,"control":null,"defaultValue":null,"label":null,"description":null,"possibleValues":null,"__typename":"FormField"},{"id":"useBackground","validation":null,"noValidation":null,"dataType":"BOOLEAN","list":null,"control":null,"defaultValue":null,"label":null,"description":null,"possibleValues":null,"__typename":"FormField"},{"id":"widgetVisibility","validation":null,"noValidation":null,"dataType":"STRING","list":null,"control":null,"defaultValue":null,"label":null,"description":null,"possibleValues":null,"__typename":"FormField"},{"id":"moreOptions","validation":null,"noValidation":null,"dataType":"STRING","list":null,"control":null,"defaultValue":null,"label":null,"description":null,"possibleValues":null,"__typename":"FormField"},{"id":"cProp_gtag","validation":null,"noValidation":null,"dataType":"STRING","list":false,"control":"INPUT","defaultValue":"","label":"Google Tag Manager Id","description":null,"possibleValues":null,"__typename":"FormField"}],"layout":{"rows":[{"id":"widgetChooserGroup","type":"fieldset","as":null,"items":[{"id":"widgetChooser","className":null,"__typename":"FormFieldRef"}],"props":null,"legend":null,"description":null,"className":null,"viewVariant":null,"toggleState":null,"__typename":"FormFieldset"},{"id":"titleGroup","type":"fieldset","as":null,"items":[{"id":"title","className":null,"__typename":"FormFieldRef"},{"id":"useTitle","className":null,"__typename":"FormFieldRef"}],"props":null,"legend":null,"description":null,"className":null,"viewVariant":null,"toggleState":null,"__typename":"FormFieldset"},{"id":"useBackground","type":"fieldset","as":null,"items":[{"id":"useBackground","className":null,"__typename":"FormFieldRef"}],"props":null,"legend":null,"description":null,"className":null,"viewVariant":null,"toggleState":null,"__typename":"FormFieldset"},{"id":"widgetVisibility","type":"fieldset","as":null,"items":[{"id":"widgetVisibility","className":null,"__typename":"FormFieldRef"}],"props":null,"legend":null,"description":null,"className":null,"viewVariant":null,"toggleState":null,"__typename":"FormFieldset"},{"id":"moreOptionsGroup","type":"fieldset","as":null,"items":[{"id":"moreOptions","className":null,"__typename":"FormFieldRef"}],"props":null,"legend":null,"description":null,"className":null,"viewVariant":null,"toggleState":null,"__typename":"FormFieldset"},{"id":"componentPropsGroup","type":"fieldset","as":null,"items":[{"id":"cProp_gtag","className":null,"__typename":"FormFieldRef"}],"props":null,"legend":null,"description":null,"className":null,"viewVariant":null,"toggleState":null,"__typename":"FormFieldset"}],"actionButtons":null,"className":"custom_widget_GoogleTagTracker_form","formGroupFieldSeparator":"divider","__typename":"FormLayout"},"__typename":"Form"},"config":null,"props":[],"__typename":"Component"}],"grouping":"CUSTOM","__typename":"ComponentTemplate"},"properties":{"config":{"applicablePages":[],"description":"Executes Google Tag tracking scripts","fetchedContent":null,"__typename":"ComponentConfiguration"},"props":[{"id":"prop_gtag","dataType":"STRING","list":false,"defaultValue":"","label":"Google Tag Manager Id","description":null,"possibleValues":null,"control":"INPUT","__typename":"PropDefinition"}],"__typename":"ComponentProperties"},"form":{"fields":[{"id":"widgetChooser","validation":null,"noValidation":null,"dataType":"STRING","list":null,"control":null,"defaultValue":null,"label":null,"description":null,"possibleValues":null,"__typename":"FormField"},{"id":"title","validation":null,"noValidation":null,"dataType":"STRING","list":null,"control":null,"defaultValue":null,"label":null,"description":null,"possibleValues":null,"__typename":"FormField"},{"id":"useTitle","validation":null,"noValidation":null,"dataType":"BOOLEAN","list":null,"control":null,"defaultValue":null,"label":null,"description":null,"possibleValues":null,"__typename":"FormField"},{"id":"useBackground","validation":null,"noValidation":null,"dataType":"BOOLEAN","list":null,"control":null,"defaultValue":null,"label":null,"description":null,"possibleValues":null,"__typename":"FormField"},{"id":"widgetVisibility","validation":null,"noValidation":null,"dataType":"STRING","list":null,"control":null,"defaultValue":null,"label":null,"description":null,"possibleValues":null,"__typename":"FormField"},{"id":"moreOptions","validation":null,"noValidation":null,"dataType":"STRING","list":null,"control":null,"defaultValue":null,"label":null,"description":null,"possibleValues":null,"__typename":"FormField"},{"id":"cProp_gtag","validation":null,"noValidation":null,"dataType":"STRING","list":false,"control":"INPUT","defaultValue":"","label":"Google Tag Manager Id","description":null,"possibleValues":null,"__typename":"FormField"}],"layout":{"rows":[{"id":"widgetChooserGroup","type":"fieldset","as":null,"items":[{"id":"widgetChooser","className":null,"__typename":"FormFieldRef"}],"props":null,"legend":null,"description":null,"className":null,"viewVariant":null,"toggleState":null,"__typename":"FormFieldset"},{"id":"titleGroup","type":"fieldset","as":null,"items":[{"id":"title","className":null,"__typename":"FormFieldRef"},{"id":"useTitle","className":null,"__typename":"FormFieldRef"}],"props":null,"legend":null,"description":null,"className":null,"viewVariant":null,"toggleState":null,"__typename":"FormFieldset"},{"id":"useBackground","type":"fieldset","as":null,"items":[{"id":"useBackground","className":null,"__typename":"FormFieldRef"}],"props":null,"legend":null,"description":null,"className":null,"viewVariant":null,"toggleState":null,"__typename":"FormFieldset"},{"id":"widgetVisibility","type":"fieldset","as":null,"items":[{"id":"widgetVisibility","className":null,"__typename":"FormFieldRef"}],"props":null,"legend":null,"description":null,"className":null,"viewVariant":null,"toggleState":null,"__typename":"FormFieldset"},{"id":"moreOptionsGroup","type":"fieldset","as":null,"items":[{"id":"moreOptions","className":null,"__typename":"FormFieldRef"}],"props":null,"legend":null,"description":null,"className":null,"viewVariant":null,"toggleState":null,"__typename":"FormFieldset"},{"id":"componentPropsGroup","type":"fieldset","as":null,"items":[{"id":"cProp_gtag","className":null,"__typename":"FormFieldRef"}],"props":null,"legend":null,"description":null,"className":null,"viewVariant":null,"toggleState":null,"__typename":"FormFieldset"}],"actionButtons":null,"className":"custom_widget_GoogleTagTracker_form","formGroupFieldSeparator":"divider","__typename":"FormLayout"},"__typename":"Form"},"__typename":"Component","localOverride":false},"globalCss":null,"form":{"fields":[{"id":"widgetChooser","validation":null,"noValidation":null,"dataType":"STRING","list":null,"control":null,"defaultValue":null,"label":null,"description":null,"possibleValues":null,"__typename":"FormField"},{"id":"title","validation":null,"noValidation":null,"dataType":"STRING","list":null,"control":null,"defaultValue":null,"label":null,"description":null,"possibleValues":null,"__typename":"FormField"},{"id":"useTitle","validation":null,"noValidation":null,"dataType":"BOOLEAN","list":null,"control":null,"defaultValue":null,"label":null,"description":null,"possibleValues":null,"__typename":"FormField"},{"id":"useBackground","validation":null,"noValidation":null,"dataType":"BOOLEAN","list":null,"control":null,"defaultValue":null,"label":null,"description":null,"possibleValues":null,"__typename":"FormField"},{"id":"widgetVisibility","validation":null,"noValidation":null,"dataType":"STRING","list":null,"control":null,"defaultValue":null,"label":null,"description":null,"possibleValues":null,"__typename":"FormField"},{"id":"moreOptions","validation":null,"noValidation":null,"dataType":"STRING","list":null,"control":null,"defaultValue":null,"label":null,"description":null,"possibleValues":null,"__typename":"FormField"},{"id":"cProp_gtag","validation":null,"noValidation":null,"dataType":"STRING","list":false,"control":"INPUT","defaultValue":"","label":"Google Tag Manager Id","description":null,"possibleValues":null,"__typename":"FormField"}],"layout":{"rows":[{"id":"widgetChooserGroup","type":"fieldset","as":null,"items":[{"id":"widgetChooser","className":null,"__typename":"FormFieldRef"}],"props":null,"legend":null,"description":null,"className":null,"viewVariant":null,"toggleState":null,"__typename":"FormFieldset"},{"id":"titleGroup","type":"fieldset","as":null,"items":[{"id":"title","className":null,"__typename":"FormFieldRef"},{"id":"useTitle","className":null,"__typename":"FormFieldRef"}],"props":null,"legend":null,"description":null,"className":null,"viewVariant":null,"toggleState":null,"__typename":"FormFieldset"},{"id":"useBackground","type":"fieldset","as":null,"items":[{"id":"useBackground","className":null,"__typename":"FormFieldRef"}],"props":null,"legend":null,"description":null,"className":null,"viewVariant":null,"toggleState":null,"__typename":"FormFieldset"},{"id":"widgetVisibility","type":"fieldset","as":null,"items":[{"id":"widgetVisibility","className":null,"__typename":"FormFieldRef"}],"props":null,"legend":null,"description":null,"className":null,"viewVariant":null,"toggleState":null,"__typename":"FormFieldset"},{"id":"moreOptionsGroup","type":"fieldset","as":null,"items":[{"id":"moreOptions","className":null,"__typename":"FormFieldRef"}],"props":null,"legend":null,"description":null,"className":null,"viewVariant":null,"toggleState":null,"__typename":"FormFieldset"},{"id":"componentPropsGroup","type":"fieldset","as":null,"items":[{"id":"cProp_gtag","className":null,"__typename":"FormFieldRef"}],"props":null,"legend":null,"description":null,"className":null,"viewVariant":null,"toggleState":null,"__typename":"FormFieldset"}],"actionButtons":null,"className":"custom_widget_GoogleTagTracker_form","formGroupFieldSeparator":"divider","__typename":"FormLayout"},"__typename":"Form"}},"localOverride":false},"CachedAsset:component:custom.widget.MixPanelTracker-en-1742463372930":{"__typename":"CachedAsset","id":"component:custom.widget.MixPanelTracker-en-1742463372930","value":{"component":{"id":"custom.widget.MixPanelTracker","template":{"id":"MixPanelTracker","markupLanguage":"HANDLEBARS","style":null,"texts":null,"defaults":{"config":{"applicablePages":[],"description":"Executes MixPanel tracking scripts","fetchedContent":null,"__typename":"ComponentConfiguration"},"props":[],"__typename":"ComponentProperties"},"components":[{"id":"custom.widget.MixPanelTracker","form":null,"config":null,"props":[],"__typename":"Component"}],"grouping":"CUSTOM","__typename":"ComponentTemplate"},"properties":{"config":{"applicablePages":[],"description":"Executes MixPanel tracking scripts","fetchedContent":null,"__typename":"ComponentConfiguration"},"props":[],"__typename":"ComponentProperties"},"form":null,"__typename":"Component","localOverride":false},"globalCss":null,"form":null},"localOverride":false},"CachedAsset:component:custom.widget.custom_Footer-en-1742463372930":{"__typename":"CachedAsset","id":"component:custom.widget.custom_Footer-en-1742463372930","value":{"component":{"id":"custom.widget.custom_Footer","template":{"id":"custom_Footer","markupLanguage":"HTML","style":null,"texts":null,"defaults":{"config":{"applicablePages":[],"description":"footer links and copy write text","fetchedContent":null,"__typename":"ComponentConfiguration"},"props":[],"__typename":"ComponentProperties"},"components":[{"id":"custom.widget.custom_Footer","form":null,"config":null,"props":[],"__typename":"Component"}],"grouping":"TEXTHTML","__typename":"ComponentTemplate"},"properties":{"config":{"applicablePages":[],"description":"footer links and copy write text","fetchedContent":null,"__typename":"ComponentConfiguration"},"props":[],"__typename":"ComponentProperties"},"form":null,"__typename":"Component","localOverride":false},"globalCss":null,"form":null},"localOverride":false},"CachedAsset:text:en_US-components/community/Navbar-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-components/community/Navbar-1739990369000","value":{"community":"Community Home","inbox":"Inbox","manageContent":"Manage Content","tos":"Terms of Service","forgotPassword":"Forgot Password","themeEditor":"Theme Editor","edit":"Edit Navigation Bar","skipContent":"Skip to content","external-1":" My Email","external-10":"child 1","mucxz84639":"Home","about-community":"About the Community","external":"Test","external-9":"Bill History","external-8":"Bill Summary","external-7":"Pay Now","mucxz84639-1":"Billing","external-6":"Alerts","external-5":"Service Repair Order","external-4":"My Services & Plan","external-3":"Manage Username / Logins","external-2":"My Information"},"localOverride":false},"CachedAsset:text:en_US-components/community/NavbarHamburgerDropdown-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-components/community/NavbarHamburgerDropdown-1739990369000","value":{"hamburgerLabel":"Side Menu"},"localOverride":false},"CachedAsset:text:en_US-components/community/BrandLogo-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-components/community/BrandLogo-1739990369000","value":{"logoAlt":"Khoros","themeLogoAlt":"Brand Logo"},"localOverride":false},"CachedAsset:text:en_US-components/community/NavbarTextLinks-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-components/community/NavbarTextLinks-1739990369000","value":{"more":"More"},"localOverride":false},"CachedAsset:text:en_US-components/search/SpotlightSearchIcon-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-components/search/SpotlightSearchIcon-1739990369000","value":{"search":"Search"},"localOverride":false},"CachedAsset:text:en_US-components/authentication/AuthenticationLink-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-components/authentication/AuthenticationLink-1739990369000","value":{"title.login":"Sign In","title.registration":"Register","title.forgotPassword":"Forgot Password","title.multiAuthLogin":"Sign In"},"localOverride":false},"CachedAsset:text:en_US-components/community/Breadcrumb-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-components/community/Breadcrumb-1739990369000","value":{"navLabel":"Breadcrumbs","dropdown":"Additional parent page navigation"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageBanner-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageBanner-1739990369000","value":{"messageMarkedAsSpam":"This post has been marked as spam","messageMarkedAsSpam@board:TKB":"This article has been marked as spam","messageMarkedAsSpam@board:BLOG":"This post has been marked as spam","messageMarkedAsSpam@board:FORUM":"This discussion has been marked as spam","messageMarkedAsSpam@board:OCCASION":"This event has been marked as spam","messageMarkedAsSpam@board:IDEA":"This idea has been marked as spam","manageSpam":"Manage Spam","messageMarkedAsAbuse":"This post has been marked as abuse","messageMarkedAsAbuse@board:TKB":"This article has been marked as abuse","messageMarkedAsAbuse@board:BLOG":"This post has been marked as abuse","messageMarkedAsAbuse@board:FORUM":"This discussion has been marked as abuse","messageMarkedAsAbuse@board:OCCASION":"This event has been marked as abuse","messageMarkedAsAbuse@board:IDEA":"This idea has been marked as abuse","preModCommentAuthorText":"This comment will be published as soon as it is approved","preModCommentModeratorText":"This comment is awaiting moderation","messageMarkedAsOther":"This post has been rejected due to other reasons","messageMarkedAsOther@board:TKB":"This article has been rejected due to other reasons","messageMarkedAsOther@board:BLOG":"This post has been rejected due to other reasons","messageMarkedAsOther@board:FORUM":"This discussion has been rejected due to other reasons","messageMarkedAsOther@board:OCCASION":"This event has been rejected due to other reasons","messageMarkedAsOther@board:IDEA":"This idea has been rejected due to other reasons","messageArchived":"This post was archived on {date}","relatedUrl":"View Related Content","relatedContentText":"Showing related content","archivedContentLink":"View Archived Content"},"localOverride":false},"CachedAsset:text:en_US-components/messages/RelatedContentWidget-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/RelatedContentWidget-1739990369000","value":{"title":"Related Content","emptyDescription":"No content to show"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageListForNodeByRecentActivityWidget-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageListForNodeByRecentActivityWidget-1739990369000","value":{"title@userScope:other":"Recent Content","title@userScope:self":"Contributions","title@board:FORUM@userScope:other":"Recent Discussions","title@board:BLOG@userScope:other":"Recent Blogs","emptyDescription":"No content to show","MessageListForNodeByRecentActivityWidgetEditor.nodeScope.label":"Scope","title@instance:1722231399124":"Latest Posts","title@instance:1722321652654":"Recent Content","title@instance:1721715590817":"Latest Posts","title@instance:1722251112371":"Latest Posts"},"localOverride":false},"Conversation:conversation:143653":{"__typename":"Conversation","id":"conversation:143653","topic":{"__typename":"ForumTopicMessage","uid":143653},"lastPostingActivityTime":"2025-03-10T17:26:54.014-04:00","solved":false},"ForumTopicMessage:message:143653":{"__typename":"ForumTopicMessage","subject":"Rebate ?","conversation":{"__ref":"Conversation:conversation:143653"},"id":"message:143653","revisionNum":1,"uid":143653,"depth":0,"board":{"__ref":"Forum:board:General"},"author":{"__typename":"User","uid":123656,"login":"Kat3","registrationData":{"__typename":"RegistrationData","status":null},"deleted":false,"avatar":{"__typename":"UserAvatar","url":"https://community.hughesnet.com/t5/s/ssqng67387/m_assets/avatars/default/avatar-5.svg?time=0"}},"metrics":{"__typename":"MessageMetrics","views":48},"postTime":"2025-03-10T04:06:47.572-04:00","lastPublishTime":"2025-03-10T04:06:47.572-04:00","readOnly":false},"Conversation:conversation:143640":{"__typename":"Conversation","id":"conversation:143640","topic":{"__typename":"ForumTopicMessage","uid":143640},"lastPostingActivityTime":"2025-02-26T18:28:32.582-05:00","solved":false},"ForumTopicMessage:message:143640":{"__typename":"ForumTopicMessage","subject":"Not worth it!","conversation":{"__ref":"Conversation:conversation:143640"},"id":"message:143640","revisionNum":1,"uid":143640,"depth":0,"board":{"__ref":"Forum:board:General"},"author":{"__typename":"User","uid":152411,"login":"dena629","registrationData":{"__typename":"RegistrationData","status":null},"deleted":false,"avatar":{"__typename":"UserAvatar","url":"https://community.hughesnet.com/t5/s/ssqng67387/m_assets/avatars/default/avatar-4.svg?time=0"}},"metrics":{"__typename":"MessageMetrics","views":68},"postTime":"2025-02-26T12:00:36.392-05:00","lastPublishTime":"2025-02-26T12:00:36.392-05:00","readOnly":false},"Conversation:conversation:143633":{"__typename":"Conversation","id":"conversation:143633","topic":{"__typename":"ForumTopicMessage","uid":143633},"lastPostingActivityTime":"2025-02-26T18:25:57.733-05:00","solved":false},"ForumTopicMessage:message:143633":{"__typename":"ForumTopicMessage","subject":"Service & billing","conversation":{"__ref":"Conversation:conversation:143633"},"id":"message:143633","revisionNum":1,"uid":143633,"depth":0,"board":{"__ref":"Forum:board:General"},"author":{"__typename":"User","uid":152392,"login":"puffpuff1","registrationData":{"__typename":"RegistrationData","status":null},"deleted":false,"avatar":{"__typename":"UserAvatar","url":"https://community.hughesnet.com/t5/s/ssqng67387/m_assets/avatars/default/avatar-5.svg?time=0"}},"metrics":{"__typename":"MessageMetrics","views":120},"postTime":"2025-02-25T11:44:00.049-05:00","lastPublishTime":"2025-02-25T11:44:00.049-05:00","readOnly":false},"Conversation:conversation:143385":{"__typename":"Conversation","id":"conversation:143385","topic":{"__typename":"ForumTopicMessage","uid":143385},"lastPostingActivityTime":"2024-12-31T22:46:43.455-05:00","solved":false},"ForumTopicMessage:message:143385":{"__typename":"ForumTopicMessage","subject":"Very, very poor support","conversation":{"__ref":"Conversation:conversation:143385"},"id":"message:143385","revisionNum":1,"uid":143385,"depth":0,"board":{"__ref":"Forum:board:General"},"author":{"__typename":"User","uid":151477,"login":"themgman","registrationData":{"__typename":"RegistrationData","status":null},"deleted":false,"avatar":{"__typename":"UserAvatar","url":"https://community.hughesnet.com/t5/s/ssqng67387/m_assets/avatars/default/avatar-2.svg?time=0"}},"metrics":{"__typename":"MessageMetrics","views":117},"postTime":"2024-12-31T20:36:47.442-05:00","lastPublishTime":"2024-12-31T20:36:47.442-05:00","readOnly":false},"Conversation:conversation:143384":{"__typename":"Conversation","id":"conversation:143384","topic":{"__typename":"ForumTopicMessage","uid":143384},"lastPostingActivityTime":"2024-12-31T22:42:33.827-05:00","solved":false},"ForumTopicMessage:message:143384":{"__typename":"ForumTopicMessage","subject":"Hughesnet is a total rip-off","conversation":{"__ref":"Conversation:conversation:143384"},"id":"message:143384","revisionNum":1,"uid":143384,"depth":0,"board":{"__ref":"Forum:board:General"},"author":{"__typename":"User","uid":151476,"login":"donnaneal1964","registrationData":{"__typename":"RegistrationData","status":null},"deleted":false,"avatar":{"__typename":"UserAvatar","url":"https://community.hughesnet.com/t5/s/ssqng67387/m_assets/avatars/default/avatar-4.svg?time=0"}},"metrics":{"__typename":"MessageMetrics","views":127},"postTime":"2024-12-31T20:13:52.796-05:00","lastPublishTime":"2024-12-31T20:13:52.796-05:00","readOnly":false},"Rank:rank:5":{"__typename":"Rank","id":"rank:5","position":6,"name":"Distinguished Professor IV","color":"0000FF","icon":null,"rankStyle":"TEXT"},"User:user:21490":{"__typename":"User","id":"user:21490","uid":21490,"login":"maratsade","biography":null,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2015-06-05T03:00:00.000-04:00","confirmEmailStatus":null,"registrationAccessLevel":null,"ssoRegistrationFields":[]},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":"https://community.hughesnet.com/t5/s/ssqng67387/images/dS0yMTQ5MC04aTNCQUJDNDExNzNEOTlEOUE"},"rank":{"__ref":"Rank:rank:5"},"messagesCount":8738,"kudosGivenCount":3496,"kudosReceivedCount":4120,"kudosWeight":1,"ssoId":null,"followersCount":null,"solutionsCount":168,"entityType":"USER","eventPath":"community:ssqng67387/user:21490"},"ForumTopicMessage:message:107360":{"__typename":"ForumTopicMessage","uid":107360,"subject":"Testmy.net down?","id":"message:107360","revisionNum":1,"repliesCount":10,"author":{"__ref":"User:user:21490"},"depth":0,"hasGivenKudo":false,"board":{"__ref":"Forum:board:General"},"conversation":{"__ref":"Conversation:conversation:107360"},"moderationData":{"__ref":"ModerationData:moderation_data:107360"},"postTime":"2018-12-12T09:20:39.435-05:00","lastPublishTime":"2018-12-12T09:20:39.435-05:00","readOnly":false,"metrics":{"__typename":"MessageMetrics","views":5480},"placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"entityType":"FORUM_TOPIC","eventPath":"category:HNSupport/community:ssqng67387board:General/message:107360"},"Conversation:conversation:107360":{"__typename":"Conversation","id":"conversation:107360","solved":true,"topic":{"__ref":"ForumTopicMessage:message:107360"},"lastPostingActivityTime":"2018-12-12T14:13:53.231-05:00","lastPostTime":"2018-12-12T14:13:53.231-05:00"},"ModerationData:moderation_data:107360":{"__typename":"ModerationData","id":"moderation_data:107360","status":"APPROVED","rejectReason":null},"RelatedContentMessage:RelatedContentMessage:107360":{"__typename":"RelatedContentMessage","id":"RelatedContentMessage:107360","relatedMessage":{"__ref":"ForumTopicMessage:message:107360"}},"Rank:rank:21":{"__typename":"Rank","id":"rank:21","position":22,"name":"Freshman","color":"33CC00","icon":null,"rankStyle":"TEXT"},"User:user:137725":{"__typename":"User","id":"user:137725","uid":137725,"login":"HughesIsPitiful","biography":null,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2022-01-05T20:07:39.711-05:00","confirmEmailStatus":null,"registrationAccessLevel":null,"ssoRegistrationFields":[]},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":"https://community.hughesnet.com/t5/s/ssqng67387/images/dS0xMzc3MjUtNjk0OWlFRDMyQURBQURBMUQ5Njkw"},"rank":{"__ref":"Rank:rank:21"},"messagesCount":5,"kudosGivenCount":1,"kudosReceivedCount":2,"kudosWeight":1,"ssoId":null,"followersCount":null,"solutionsCount":0,"entityType":"USER","eventPath":"community:ssqng67387/user:137725"},"AssociatedImage:{\"url\":\"https://community.hughesnet.com/t5/s/ssqng67387/images/bi0xMS1qUHA3ZXA?image-coordinates=0%2C0%2C130%2C130\"}":{"__typename":"AssociatedImage","url":"https://community.hughesnet.com/t5/s/ssqng67387/images/bi0xMS1qUHA3ZXA?image-coordinates=0%2C0%2C130%2C130","mimeType":"image/png"},"Forum:board:TechSupport":{"__typename":"Forum","id":"board:TechSupport","entityType":"FORUM","displayId":"TechSupport","nodeType":"board","depth":2,"conversationStyle":"FORUM","title":"Tech Support","shortTitle":"Tech Support","parent":{"__ref":"Category:category:HNSupport"},"userContext":{"__typename":"NodeUserContext","canAddAttachments":false,"canUpdateNode":false,"canPostMessages":false,"isSubscribed":false},"avatar":{"__ref":"AssociatedImage:{\"url\":\"https://community.hughesnet.com/t5/s/ssqng67387/images/bi0xMS1qUHA3ZXA?image-coordinates=0%2C0%2C130%2C130\"}"},"description":"Tips and tricks to getting the most out of your Hughesnet internet and Hughesnet Voice services.","eventPath":"category:HNSupport/community:ssqng67387board:TechSupport/"},"ForumTopicMessage:message:136645":{"__typename":"ForumTopicMessage","uid":136645,"subject":"Sample 30 recent testmy.net tests- SLOWWWW","id":"message:136645","revisionNum":2,"repliesCount":10,"author":{"__ref":"User:user:137725"},"depth":0,"hasGivenKudo":false,"board":{"__ref":"Forum:board:TechSupport"},"conversation":{"__ref":"Conversation:conversation:136645"},"moderationData":{"__ref":"ModerationData:moderation_data:136645"},"postTime":"2022-01-30T23:14:19.583-05:00","lastPublishTime":"2022-01-30T23:16:30.722-05:00","readOnly":true,"metrics":{"__typename":"MessageMetrics","views":6127},"placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"entityType":"FORUM_TOPIC","eventPath":"category:HNSupport/community:ssqng67387board:TechSupport/message:136645"},"Conversation:conversation:136645":{"__typename":"Conversation","id":"conversation:136645","solved":true,"topic":{"__ref":"ForumTopicMessage:message:136645"},"lastPostingActivityTime":"2022-02-10T17:17:34.663-05:00","lastPostTime":"2022-02-10T17:17:34.663-05:00"},"ModerationData:moderation_data:136645":{"__typename":"ModerationData","id":"moderation_data:136645","status":"APPROVED","rejectReason":null},"RelatedContentMessage:RelatedContentMessage:136645":{"__typename":"RelatedContentMessage","id":"RelatedContentMessage:136645","relatedMessage":{"__ref":"ForumTopicMessage:message:136645"}},"Rank:rank:20":{"__typename":"Rank","id":"rank:20","position":21,"name":"Sophomore","color":"00CC00","icon":null,"rankStyle":"TEXT"},"User:user:121562":{"__typename":"User","id":"user:121562","uid":121562,"login":"Nan3","biography":null,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2020-12-31T02:00:27.288-05:00","confirmEmailStatus":null,"registrationAccessLevel":null,"ssoRegistrationFields":[]},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":"https://community.hughesnet.com/t5/s/ssqng67387/m_assets/avatars/default/avatar-3.svg?time=0"},"rank":{"__ref":"Rank:rank:20"},"messagesCount":12,"kudosGivenCount":0,"kudosReceivedCount":1,"kudosWeight":1,"ssoId":null,"followersCount":null,"solutionsCount":1,"entityType":"USER","eventPath":"community:ssqng67387/user:121562"},"ForumTopicMessage:message:133269":{"__typename":"ForumTopicMessage","uid":133269,"subject":"Other community members emails","id":"message:133269","revisionNum":1,"repliesCount":5,"author":{"__ref":"User:user:121562"},"depth":0,"hasGivenKudo":false,"board":{"__ref":"Forum:board:TechSupport"},"conversation":{"__ref":"Conversation:conversation:133269"},"moderationData":{"__ref":"ModerationData:moderation_data:133269"},"postTime":"2021-05-23T21:30:38.744-04:00","lastPublishTime":"2021-05-23T21:30:38.744-04:00","readOnly":true,"metrics":{"__typename":"MessageMetrics","views":3300},"placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"entityType":"FORUM_TOPIC","eventPath":"category:HNSupport/community:ssqng67387board:TechSupport/message:133269"},"Conversation:conversation:133269":{"__typename":"Conversation","id":"conversation:133269","solved":true,"topic":{"__ref":"ForumTopicMessage:message:133269"},"lastPostingActivityTime":"2021-05-23T22:49:20.175-04:00","lastPostTime":"2021-05-23T22:49:20.175-04:00"},"ModerationData:moderation_data:133269":{"__typename":"ModerationData","id":"moderation_data:133269","status":"APPROVED","rejectReason":null},"RelatedContentMessage:RelatedContentMessage:133269":{"__typename":"RelatedContentMessage","id":"RelatedContentMessage:133269","relatedMessage":{"__ref":"ForumTopicMessage:message:133269"}},"User:user:44813":{"__typename":"User","id":"user:44813","uid":44813,"login":"KatBro","biography":null,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2017-08-21T18:56:12.760-04:00","confirmEmailStatus":null,"registrationAccessLevel":null,"ssoRegistrationFields":[]},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":"https://community.hughesnet.com/t5/s/ssqng67387/m_assets/avatars/default/avatar-5.svg?time=0"},"rank":{"__ref":"Rank:rank:20"},"messagesCount":27,"kudosGivenCount":0,"kudosReceivedCount":9,"kudosWeight":1,"ssoId":null,"followersCount":null,"solutionsCount":1,"entityType":"USER","eventPath":"community:ssqng67387/user:44813"},"ForumTopicMessage:message:104601":{"__typename":"ForumTopicMessage","uid":104601,"subject":"Speed tests - Hughes website vs testmy.net","id":"message:104601","revisionNum":1,"repliesCount":3,"author":{"__ref":"User:user:44813"},"depth":0,"hasGivenKudo":false,"board":{"__ref":"Forum:board:TechSupport"},"conversation":{"__ref":"Conversation:conversation:104601"},"moderationData":{"__ref":"ModerationData:moderation_data:104601"},"postTime":"2018-09-09T00:25:56.313-04:00","lastPublishTime":"2018-09-09T00:25:56.313-04:00","readOnly":true,"metrics":{"__typename":"MessageMetrics","views":3459},"placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"entityType":"FORUM_TOPIC","eventPath":"category:HNSupport/community:ssqng67387board:TechSupport/message:104601"},"Conversation:conversation:104601":{"__typename":"Conversation","id":"conversation:104601","solved":true,"topic":{"__ref":"ForumTopicMessage:message:104601"},"lastPostingActivityTime":"2018-09-11T00:17:27.767-04:00","lastPostTime":"2018-09-11T00:17:27.767-04:00"},"ModerationData:moderation_data:104601":{"__typename":"ModerationData","id":"moderation_data:104601","status":"APPROVED","rejectReason":null},"RelatedContentMessage:RelatedContentMessage:104601":{"__typename":"RelatedContentMessage","id":"RelatedContentMessage:104601","relatedMessage":{"__ref":"ForumTopicMessage:message:104601"}},"User:user:36670":{"__typename":"User","id":"user:36670","uid":36670,"login":"Rascal777jimmy","biography":null,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2017-03-24T19:52:01.121-04:00","confirmEmailStatus":null,"registrationAccessLevel":null,"ssoRegistrationFields":[]},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":"https://community.hughesnet.com/t5/s/ssqng67387/images/dS0zNjY3MC0xNTEzaTBGQUM1MkE2MzYwQjU1MkU"},"rank":{"__ref":"Rank:rank:20"},"messagesCount":14,"kudosGivenCount":7,"kudosReceivedCount":4,"kudosWeight":1,"ssoId":null,"followersCount":null,"solutionsCount":0,"entityType":"USER","eventPath":"community:ssqng67387/user:36670"},"ForumTopicMessage:message:86897":{"__typename":"ForumTopicMessage","uid":86897,"subject":"Same problem as others !","id":"message:86897","revisionNum":1,"repliesCount":5,"author":{"__ref":"User:user:36670"},"depth":0,"hasGivenKudo":false,"board":{"__ref":"Forum:board:General"},"conversation":{"__ref":"Conversation:conversation:86897"},"moderationData":{"__ref":"ModerationData:moderation_data:86897"},"postTime":"2017-11-16T11:24:56.042-05:00","lastPublishTime":"2017-11-16T11:24:56.042-05:00","readOnly":false,"metrics":{"__typename":"MessageMetrics","views":4621},"placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"entityType":"FORUM_TOPIC","eventPath":"category:HNSupport/community:ssqng67387board:General/message:86897"},"Conversation:conversation:86897":{"__typename":"Conversation","id":"conversation:86897","solved":true,"topic":{"__ref":"ForumTopicMessage:message:86897"},"lastPostingActivityTime":"2017-11-18T02:59:37.792-05:00","lastPostTime":"2017-11-18T02:59:37.792-05:00"},"ModerationData:moderation_data:86897":{"__typename":"ModerationData","id":"moderation_data:86897","status":"APPROVED","rejectReason":null},"RelatedContentMessage:RelatedContentMessage:86897":{"__typename":"RelatedContentMessage","id":"RelatedContentMessage:86897","relatedMessage":{"__ref":"ForumTopicMessage:message:86897"}},"CachedAsset:text:en_US-components/nodes/NodeLink-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-components/nodes/NodeLink-1739990369000","value":{"place":"Place {name}"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageView/MessageViewStandard-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageView/MessageViewStandard-1739990369000","value":{"anonymous":"Anonymous","author":"{messageAuthorLogin}","authorBy":"{messageAuthorLogin}","board":"{messageBoardTitle}","replyToUser":" to {parentAuthor}","showMoreReplies":"Show More","replyText":"Reply","repliesText":"Replies","markedAsSolved":"Marked as Solved","movedMessagePlaceholder.BLOG":"{count, plural, =0 {This comment has been} other {These comments have been} }","movedMessagePlaceholder.TKB":"{count, plural, =0 {This comment has been} other {These comments have been} }","movedMessagePlaceholder.FORUM":"{count, plural, =0 {This reply has been} other {These replies have been} }","movedMessagePlaceholder.IDEA":"{count, plural, =0 {This comment has been} other {These comments have been} }","movedMessagePlaceholder.OCCASION":"{count, plural, =0 {This comment has been} other {These comments have been} }","movedMessagePlaceholderUrlText":"moved.","messageStatus":"Status: ","statusChanged":"Status changed: {previousStatus} to {currentStatus}","statusAdded":"Status added: {status}","statusRemoved":"Status removed: {status}","labelExpand":"expand replies","labelCollapse":"collapse replies","unhelpfulReason.reason1":"Content is outdated","unhelpfulReason.reason2":"Article is missing information","unhelpfulReason.reason3":"Content is for a different Product","unhelpfulReason.reason4":"Doesn't match what I was searching for"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageDeepLink-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageDeepLink-1739990369000","value":{"viewFullDiscussion@board:FORUM":"View Full Discussion ({repliesCount} Replies)","viewFullDiscussion@board:BLOG":"View Full Discussion ({repliesCount} Comments)","viewFullDiscussion@board:TKB":"View Full Discussion ({repliesCount} Comments)","viewFullDiscussion@board:IDEA":"View Full Discussion ({repliesCount} Comments)","viewFullDiscussion@board:OCCASION":"View Full Discussion ({repliesCount} Comments)","showParents@board:FORUM":"Show Parent Replies","showParents@board:BLOG":"Show Parent Comments","showParents@board:TKB":"Show Parent Comments","showParents@board:IDEA":"Show Parent Comments","showParents@board:OCCASION":"Show Parent Comments"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageReplyCallToAction-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageReplyCallToAction-1739990369000","value":{"leaveReply":"Leave a reply...","leaveReply@board:BLOG@message:root":"Leave a comment...","leaveReply@board:TKB@message:root":"Leave a comment...","leaveReply@board:IDEA@message:root":"Leave a comment...","leaveReply@board:OCCASION@message:root":"Leave a comment...","repliesTurnedOff.FORUM":"Replies are turned off for this topic","repliesTurnedOff.BLOG":"Comments are turned off for this topic","repliesTurnedOff.TKB":"Comments are turned off for this topic","repliesTurnedOff.IDEA":"Comments are turned off for this topic","repliesTurnedOff.OCCASION":"Comments are turned off for this topic","infoText":"Stop poking me!"},"localOverride":false},"CachedAsset:text:en_US-shared/client/components/common/QueryHandler-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/common/QueryHandler-1739990369000","value":{"title":"Query Handler"},"localOverride":false},"CachedAsset:text:en_US-components/messages/EscalatedMessageBanner-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/EscalatedMessageBanner-1739990369000","value":{"escalationMessage":"Escalated to Salesforce by {username} on {date}","viewDetails":"View Details","modalTitle":"Case Details","escalatedBy":"Escalated by: ","escalatedOn":"Escalated on: ","caseNumber":"Case Number: ","status":"Status: ","lastUpdateDate":"Last Update: ","automaticEscalation":"automatic escalation","anonymous":"Anonymous"},"localOverride":false},"CachedAsset:text:en_US-components/users/UserLink-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-components/users/UserLink-1739990369000","value":{"authorName":"View Profile: {author}","anonymous":"Anonymous"},"localOverride":false},"CachedAsset:text:en_US-shared/client/components/users/UserRank-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/users/UserRank-1739990369000","value":{"rankName":"{rankName}","userRank":"Author rank {rankName}"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageTime-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageTime-1739990369000","value":{"postTime":"Published: {time}","lastPublishTime":"Last Update: {time}","conversation.lastPostingActivityTime":"Last posting activity time: {time}","conversation.lastPostTime":"Last post time: {time}","moderationData.rejectTime":"Rejected time: {time}"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageSolvedBadge-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageSolvedBadge-1739990369000","value":{"solved":"Solved"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageSubject-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageSubject-1739990369000","value":{"noSubject":"(no subject)"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageBody-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageBody-1739990369000","value":{"showMessageBody":"Show More","mentionsErrorTitle":"{mentionsType, select, board {Board} user {User} message {Message} other {}} No Longer Available","mentionsErrorMessage":"The {mentionsType} you are trying to view has been removed from the community.","videoProcessing":"Video is being processed. Please try again in a few minutes.","bannerTitle":"Video provider requires cookies to play the video. Accept to continue or {url} it directly on the provider's site.","buttonTitle":"Accept","urlText":"watch"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageCustomFields-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageCustomFields-1739990369000","value":{"CustomField.default.label":"Value of {name}"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageReplyButton-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageReplyButton-1739990369000","value":{"repliesCount":"{count}","title":"Reply","title@board:BLOG@message:root":"Comment","title@board:TKB@message:root":"Comment","title@board:IDEA@message:root":"Comment","title@board:OCCASION@message:root":"Comment"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageView/MessageViewInline-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageView/MessageViewInline-1739990369000","value":{"bylineAuthor":"{bylineAuthor}","bylineBoard":"{bylineBoard}","anonymous":"Anonymous","place":"Place {bylineBoard}","gotoParent":"Go to parent {name}"},"localOverride":false},"CachedAsset:text:en_US-shared/client/components/common/Pager/PagerLoadMore-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/common/Pager/PagerLoadMore-1739990369000","value":{"loadMore":"Show More"},"localOverride":false},"CachedAsset:text:en_US-components/customComponent/CustomComponent-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-components/customComponent/CustomComponent-1739990369000","value":{"errorMessage":"Error rendering component id: {customComponentId}","bannerTitle":"Video provider requires cookies to play the video. Accept to continue or {url} it directly on the provider's site.","buttonTitle":"Accept","urlText":"watch"},"localOverride":false},"Rank:rank:9":{"__typename":"Rank","id":"rank:9","position":10,"name":"Professor","color":"0066FF","icon":null,"rankStyle":"TEXT"},"User:user:12376":{"__typename":"User","id":"user:12376","uid":12376,"login":"MarkJFine","deleted":false,"avatar":{"__typename":"UserAvatar","url":"https://community.hughesnet.com/t5/s/ssqng67387/images/dS0xMjM3Ni03MTZpQkQzREUyMzhFQTA2OThCMw"},"rank":{"__ref":"Rank:rank:9"},"email":"","messagesCount":3234,"biography":null,"topicsCount":85,"kudosReceivedCount":1989,"kudosGivenCount":1027,"kudosWeight":1,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2012-10-29T03:00:00.000-04:00","confirmEmailStatus":null},"followersCount":null,"solutionsCount":78,"entityType":"USER","eventPath":"community:ssqng67387/user:12376"},"ModerationData:moderation_data:128620":{"__typename":"ModerationData","id":"moderation_data:128620","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"ModerationData:moderation_data:128607":{"__typename":"ModerationData","id":"moderation_data:128607","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"ForumReplyMessage:message:128607":{"__typename":"ForumReplyMessage","id":"message:128607","revisionNum":1,"uid":128607,"depth":17,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:General"},"conversation":{"__ref":"Conversation:conversation:127931"},"subject":"Re: Using TestMy.net to compare your speed to others on your beam","readOnly":false,"editFrozen":false,"moderationData":{"__ref":"ModerationData:moderation_data:128607"},"body":"
maratsade wrote:To be honest, it's probably a lot simpler explanation like the network periodically adjusting the load.
Occam's razor.
Yes, excellent point about the load balancing! Although I don't know much about how this works, it seems that the bandwidth of the beam (at least for download) is divided among the \"Out Routes\". I noticed that not only has my IPGW not changed since the 11th, neither has my outroute, and I think that normally changes fairly often, like every day or two at some seemingly random time. So maybe something that does the load balancing has stopped working on my beam and people who reboot are getting crowded onto a busy out route, while out route 4 becomes increasingly empty! I was going to reboot my modem last night, but held off when I began to suspect something -- even though my evidence is flimsy at best.
I could reboot tonight and see what happens -- but if this wild hypothesis about load balancing is remotely correct and I end up on a crowded out route then I will be very sad :-(
Of course, maybe the fantastic performance I am seeing is just the result of the great crush of traffic from the pandemic being over and I am finally seeing the result of those gateway upgrades they appear to have rolled out earlier this year. Although the speed tests I ran last night in prime time were eye popping, it was Saturday evening, so things are a little different for Saturday. Sunday usually appears to have more activity in the afternoon, so maybe I can retest then to see what happens.
We could also ask that fellow with the issue for his beam, IPGW, and out route to see if there is anything even remotely lining up, after all, if he is in Utah then there can not be anything here right?
So if we ask the fellow with the issue for beam/IPGW/out route, and he is on my beam with a different out route, and I see crazy high benchmarks consistently over 50Mbps again this afternoon which is usually fairly busy on a Sunday, and if I reboot to find myself in purgatory at 7pm tonight, then maybe there is something to this load balancing idea?
If the first two look to be true, I might not have the courage to reboot though.... :-)
What do you think?
","body@stringLength":"2708","rawBody":"
wrote: To be honest, it's probably a lot simpler explanation like the network periodically adjusting the load.
Occam's razor.
What do you think?
","author":{"__ref":"User:user:71041"},"isEscalated":null,"postTime":"2020-10-25T11:09:12.486-04:00","solution":false,"customFields":[],"attachments":{"__typename":"AttachmentConnection","edges":[],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"kudosSumWeight":0,"repliesCount":3,"images":{"__typename":"AssociatedImageConnection","edges":[],"totalCount":0,"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"timeToRead":2,"currentRevision":{"__ref":"Revision:revision:128607_1"},"latestVersion":null,"metrics":{"__typename":"MessageMetrics","views":8008},"visibilityScope":"PUBLIC","placeholder":false,"originalMessageForPlaceholder":null,"messagePolicies":{"__typename":"MessagePolicies","canModerateSpamMessage":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.feature.moderation_spam.action.moderate_entity.allowed.accessDenied","key":"error.lithium.policies.feature.moderation_spam.action.moderate_entity.allowed.accessDenied","args":[]}}}},"Revision:revision:128620_1":{"__typename":"Revision","id":"revision:128620_1","lastEditTime":"2020-10-25T13:55:50.254-04:00"},"QueryVariables:ReplyList:message:128620:1":{"__typename":"QueryVariables","id":"ReplyList:message:128620:1","value":{"id":"message:128620","sorts":{"postTime":{"direction":"ASC"}},"useAvatar":true,"useAuthorLogin":true,"useAuthorRank":true,"useBody":true,"useKudosCount":true,"useTimeToRead":false,"useMedia":false,"useReadOnlyIcon":false,"useRepliesCount":false,"useSearchSnippet":false,"useAcceptedSolutionButton":true,"useSolvedBadge":false,"useAttachments":false,"attachmentsFirst":5,"useTags":false,"useNodeAncestors":false,"useUserHoverCard":false,"useNodeHoverCard":false,"useModerationStatus":true,"usePreviewSubjectModal":false,"useMessageStatus":true}},"ROOT_MUTATION":{"__typename":"Mutation"},"CachedAsset:text:en_US-shared/client/components/users/UserAvatar-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/users/UserAvatar-1739990369000","value":{"altText":"{login}'s avatar","altTextGeneric":"User's avatar"},"localOverride":false},"CachedAsset:text:en_US-shared/client/components/ranks/UserRankLabel-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/ranks/UserRankLabel-1739990369000","value":{"altTitle":"Icon for {rankName} rank"},"localOverride":false},"CachedAsset:text:en_US-components/messages/AcceptedSolutionButton-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/AcceptedSolutionButton-1739990369000","value":{"accept":"Mark as Solution","accepted":"Marked as Solution","errorHeader":"Error!","errorAdd":"There was an error marking as solution.","errorRemove":"There was an error unmarking as solution.","solved":"Solved","topicAlreadySolvedErrorTitle":"Solution Already Exists","topicAlreadySolvedErrorDesc":"Refresh the browser to view the existing solution"},"localOverride":false},"CachedAsset:text:en_US-components/messages/LinearReplyList-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/LinearReplyList-1739990369000","value":{"title":"{count, plural, one{# Reply} other{# Replies}}","title@board:BLOG":"{count, plural, one{# Comment} other{# Comments}}","title@board:TKB":"{count, plural, one{# Comment} other{# Comments}}","title@board:IDEA":"{count, plural, one{# Comment} other{# Comments}}","title@board:OCCASION":"{count, plural, one{# Comment} other{# Comments}}","noRepliesTitle":"No Replies","noRepliesTitle@board:BLOG":"No Comments","noRepliesTitle@board:TKB":"No Comments","noRepliesTitle@board:IDEA":"No Comments","noRepliesTitle@board:OCCASION":"No Comments","noRepliesDescription":"Be the first to reply","noRepliesDescription@board:BLOG":"Be the first to comment","noRepliesDescription@board:TKB":"Be the first to comment","noRepliesDescription@board:OCCASION":"Be the first to comment","noRepliesDescription@board:IDEA":"Be the first to comment","messageReadOnlyAlert:BLOG":"Comments have been turned off for this post","messageReadOnlyAlert:TKB":"Comments have been turned off for this article","messageReadOnlyAlert:IDEA":"Comments have been turned off for this idea","messageReadOnlyAlert:FORUM":"Replies have been turned off for this discussion","messageReadOnlyAlert:OCCASION":"Comments have been turned off for this event"},"localOverride":false},"CachedAsset:text:en_US-shared/client/components/nodes/NodeIcon-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/nodes/NodeIcon-1739990369000","value":{"contentType":"Content Type {style, select, FORUM {Forum} BLOG {Blog} TKB {Knowledge Base} IDEA {Ideas} OCCASION {Events} other {}} icon"},"localOverride":false},"Revision:revision:128607_1":{"__typename":"Revision","id":"revision:128607_1","lastEditTime":"2020-10-25T11:09:12.486-04:00"},"ModerationData:moderation_data:128622":{"__typename":"ModerationData","id":"moderation_data:128622","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"ForumReplyMessage:message:128622":{"__typename":"ForumReplyMessage","author":{"__ref":"User:user:71041"},"id":"message:128622","revisionNum":1,"uid":128622,"depth":19,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:General"},"parent":{"__ref":"ForumReplyMessage:message:128620"},"conversation":{"__ref":"Conversation:conversation:127931"},"subject":"Re: Using TestMy.net to compare your speed to others on your beam","moderationData":{"__ref":"ModerationData:moderation_data:128622"},"body":"
Yes, exactly -- but if that process quit working for a bit it might be a problem as on reboot people might begin to accumulate on one IPGW. There may be a similar process with Out Route?
Anyway, from his testing, I see a third city show up that is 140 miles from the approximate beam 82 center. With my testmy results, the locations were within 60 miles of beam center 2/3 of the time, and the rest were within 90 miles. Maratsade had a larger distance, but with 140 miles (and that is if he is actually beam 82, so maybe the location data is even worse than this!) then maybe test scores are not just mixed in with J1 beams, but also neighboring J2 beams.
Also, I have been running test this afternoon, and they are not above 50Mbps, but looking good in the high 30's to mid 40's, so it is beginning to appear there is nothing to this and that I just had a streak of really high tests for a bit.
I also do a regular reboot, the early patches would get squirrelly after a week, but they seem a bit better now, so I try to reboot every two weeks. I don't think I need to worry about rebooting this evening and finding myself in slow-ville.
Do you think I should ask the fellow to confirm his beam/IPGW/Out route? I don't want to waste his time with a wild goose chase.
","body@stripHtml({\"removeProcessingText\":false,\"removeSpoilerMarkup\":false,\"removeTocMarkup\":false,\"truncateLength\":200})@stringLength":"213","kudosSumWeight":0,"postTime":"2020-10-25T14:22:04.049-04:00","lastPublishTime":"2020-10-25T14:22:04.049-04:00","metrics":{"__typename":"MessageMetrics","views":7989},"visibilityScope":"PUBLIC","placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"solution":false,"entityType":"FORUM_REPLY","eventPath":"category:HNSupport/community:ssqng67387board:General/message:127931/message:128622","repliesCount":1,"readOnly":false,"customFields":[],"attachments":{"__typename":"AttachmentConnection","edges":[],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"editFrozen":false,"body@stringLength":"1404","rawBody":"
","images":{"__typename":"AssociatedImageConnection","edges":[],"totalCount":0,"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"timeToRead":1,"currentRevision":{"__ref":"Revision:revision:128622_1"},"latestVersion":null,"messagePolicies":{"__typename":"MessagePolicies","canModerateSpamMessage":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.feature.moderation_spam.action.moderate_entity.allowed.accessDenied","key":"error.lithium.policies.feature.moderation_spam.action.moderate_entity.allowed.accessDenied","args":[]}}}},"ModerationData:moderation_data:128623":{"__typename":"ModerationData","id":"moderation_data:128623","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"ForumReplyMessage:message:128623":{"__typename":"ForumReplyMessage","author":{"__ref":"User:user:12376"},"id":"message:128623","revisionNum":1,"uid":128623,"depth":20,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:General"},"parent":{"__ref":"ForumReplyMessage:message:128622"},"conversation":{"__ref":"Conversation:conversation:127931"},"subject":"Re: Using TestMy.net to compare your speed to others on your beam","moderationData":{"__ref":"ModerationData:moderation_data:128623"},"body":"
Can always see if the guy will respond.
","body@stripHtml({\"removeProcessingText\":false,\"removeSpoilerMarkup\":false,\"removeTocMarkup\":false,\"truncateLength\":200})@stringLength":"41","kudosSumWeight":0,"postTime":"2020-10-25T14:56:53.939-04:00","lastPublishTime":"2020-10-25T14:56:53.939-04:00","metrics":{"__typename":"MessageMetrics","views":7994},"visibilityScope":"PUBLIC","placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"solution":false,"entityType":"FORUM_REPLY","eventPath":"category:HNSupport/community:ssqng67387board:General/message:127931/message:128623","repliesCount":0,"customFields":[],"attachments":{"__typename":"AttachmentConnection","edges":[],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"readOnly":false,"editFrozen":false,"body@stringLength":"46","rawBody":"Can always see if the guy will respond.
","images":{"__typename":"AssociatedImageConnection","edges":[],"totalCount":0,"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"timeToRead":1,"currentRevision":{"__ref":"Revision:revision:128623_1"},"latestVersion":null,"messagePolicies":{"__typename":"MessagePolicies","canModerateSpamMessage":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.feature.moderation_spam.action.moderate_entity.allowed.accessDenied","key":"error.lithium.policies.feature.moderation_spam.action.moderate_entity.allowed.accessDenied","args":[]}}}},"CachedAsset:text:en_US-components/tags/TagView/TagViewChip-1739990369000":{"__typename":"CachedAsset","id":"text:en_US-components/tags/TagView/TagViewChip-1739990369000","value":{"tagLabelName":"Tag name {tagName}"},"localOverride":false},"Revision:revision:128623_1":{"__typename":"Revision","id":"revision:128623_1","lastEditTime":"2020-10-25T14:56:53.939-04:00"},"Revision:revision:128622_1":{"__typename":"Revision","id":"revision:128622_1","lastEditTime":"2020-10-25T14:22:04.049-04:00"}}}},"page":"/forums/ForumMessagePage/ForumMessagePage","query":{"boardId":"General","messageSubject":"using-testmy-net-to-compare-your-speed-to-others-on-your-beam","messageId":"127931","replyId":"128620"},"buildId":"q_bLpq2mflH0BeZigxpj6","runtimeConfig":{"buildInformationVisible":false,"logLevelApp":"info","logLevelMetrics":"info","openTelemetryClientEnabled":false,"openTelemetryConfigName":"hughes","openTelemetryServiceVersion":"25.2.0","openTelemetryUniverse":"prod","openTelemetryCollector":"http://localhost:4318","openTelemetryRouteChangeAllowedTime":"5000","apolloDevToolsEnabled":false,"inboxMuteWipFeatureEnabled":false},"isFallback":false,"isExperimentalCompile":false,"dynamicIds":["./components/seo/QAPageSchema/QAPageSchema.tsx","./components/community/Navbar/NavbarWidget.tsx","./components/community/Breadcrumb/BreadcrumbWidget.tsx","./components/customComponent/CustomComponent/CustomComponent.tsx","./components/messages/TopicWithThreadedReplyListWidget/TopicWithThreadedReplyListWidget.tsx","./components/messages/RelatedContentWidget/RelatedContentWidget.tsx","./components/messages/MessageListForNodeByRecentActivityWidget/MessageListForNodeByRecentActivityWidget.tsx","./components/messages/MessageView/MessageViewStandard/MessageViewStandard.tsx","./components/customComponent/CustomComponentContent/TemplateContent.tsx","../shared/client/components/common/List/UnstyledList/UnstyledList.tsx","./components/messages/MessageView/MessageView.tsx","./components/messages/MessageView/MessageViewInline/MessageViewInline.tsx","../shared/client/components/common/List/ListGroup/ListGroup.tsx","../shared/client/components/common/Pager/PagerLoadMore/PagerLoadMore.tsx","./components/customComponent/CustomComponentContent/HtmlContent.tsx","./components/customComponent/CustomComponentContent/CustomComponentScripts.tsx","../shared/client/components/common/List/UnwrappedList/UnwrappedList.tsx","./components/tags/TagView/TagView.tsx","./components/tags/TagView/TagViewChip/TagViewChip.tsx"],"appGip":true,"scriptLoader":[{"id":"mixPanel","src":"https://community.hughesnet.com/t5/s/ssqng67387/pagescripts/1733832053000/mixPanel.js?page.id=ForumReplyPage&entity.id=board%3AGeneral&entity.id=message%3A128620","strategy":"afterInteractive"}]}
