Using TestMy.net to compare your speed to others on your beam
Rebooting always pops you into a lesser used IPGW. It will also have the benefit of refreshing the DNS cache, which is always good. Sometimes that thing gets corrupted. I usually end up rebooting at least once a week, because my wife likes to work downstairs, away from the modem, which doesn't always have a good wifi signal. That's usually a good formula for a busted DNS cache.
Yes, exactly -- but if that process quit working for a bit it might be a problem as on reboot people might begin to accumulate on one IPGW. There may be a similar process with Out Route?
Anyway, from his testing, I see a third city show up that is 140 miles from the approximate beam 82 center. With my testmy results, the locations were within 60 miles of beam center 2/3 of the time, and the rest were within 90 miles. Maratsade had a larger distance, but with 140 miles (and that is if he is actually beam 82, so maybe the location data is even worse than this!) then maybe test scores are not just mixed in with J1 beams, but also neighboring J2 beams.
Also, I have been running test this afternoon, and they are not above 50Mbps, but looking good in the high 30's to mid 40's, so it is beginning to appear there is nothing to this and that I just had a streak of really high tests for a bit.
I also do a regular reboot, the early patches would get squirrelly after a week, but they seem a bit better now, so I try to reboot every two weeks. I don't think I need to worry about rebooting this evening and finding myself in slow-ville.
Do you think I should ask the fellow to confirm his beam/IPGW/Out route? I don't want to waste his time with a wild goose chase.
Can always see if the guy will respond.
