Timothy Southwa
9 years agoNot applicable
Average modem power consumption in watts?
I'm off grid and I need to know the average modem power consumption in watts when not doing much uploading or any gaming at all.
- 9 years agoGood morning,
The engineer pointed me to this page in the Jupiter install guide on pg 15, http://customer.kb.hughesnet.com/Documents/1039649-0001_c.pdf the rated power consumption of the HT1100 is 46W. That's all the info we have as far as power usage.
C0RR0SIVE
9 years agoAssociate Professor
Honestly, it will depend... With you being off-grid you shouldn't depend on the "average" power usage, but the possible highest usage as well so that you don't overload your personal grid, unless you can predict when the signal will drop out and the modem ramps up transmission power and processing to try and keep a signal lock.
The label on the power brick states (at least on mine) Input at 100-130V @ 2.0A (which at maximum theoretical value is 260w), and the output is listed as 46w.
The only time these modems will use a TON of power is during heavy cloud cover, rain, and when it's acquiring a signal after being powered on, so you may want to plan for possible high wattage surges during those scenarios.
Power usage also depends upon how well your satellite is aimed, as well as general location in your beam assignment.
