Bandwidth problems.
BirdDog wrote:Amazon can be pretty sketchy because a lot of their video is only HD and does not adapt to the user end speed.
If you're watching on their site, you can downgrade the video quality to "Good," which uses about 380 MB per hour. I've tested this and it works. The app doesn't have a way to downgrade the video quality that I could see.
I didn't know they added that as don't watch that much Amazon streaming, nice they did. Since I usually watch casting from the app wouldn't do me any good, wonder if built in smart TV app allows it. Will have to check.
Yeah, I love that you can control the quality on the website. I hope they add it to the app too. I tested it on the iPad but couldn't find a setting at all, and so I streamed for a bit and saw it inhales data. So no app for me. I've never used the apps that come with the TV, so I don't know if they have a setting to control video definition, but it'd be nice if they did, since so many people use those apps. Nowadays I just use the HDMI cable method and connect a laptop to the TV. Works a treat.
BirdDog wrote:I didn't know they added that as don't watch that much Amazon streaming, nice they did. Since I usually watch casting from the app wouldn't do me any good, wonder if built in smart TV app allows it. Will have to check.
