You should try the following...
1. Shut down your connected devices.
2. Turn off your router.
3. Unplug your HughesNet modem from either the wall outlet or the power brick (NOT at the back of the modem), then disconnect your router from the modem.
4. Connect your desktop directly to the HughesNet modem with a LAN cable.
5. Wait at least a minute (from when you first unplugged the modem), then plug your HughesNet modem back in.
6. Wait at least five minutes so that the HughesNet modem is fully up and ready, then start up the directly connected desktop and try to go to the sites.
7. If that works, then shut the desktop back down and disconnect it from the modem. Then reconnect the router to the modem, reconnect your desktop to the router, turn the router on, wait a few minutes for the router to be fully up, then start the desktop again and retry the sites. If it works, try your other devices.
I tried all that a couple of days after this all started. No joy.
System Restore did not work last night either. Not that I expected it to.
