I had a similar problem last year, except it effected several sites for three days. I think your problem is probably somewhere out in that never-never land past the Hughes gateway. When I run a traceroute from a Linux terminal for aol.com it goes through 30 hops. I don't claim to be an expert on all this, but it seems to me that a problem with any of these hops could make aol.com unreachable. Your hot spot is probably not using the bad hop and therefore works.
I know this is not going to be much help, but I've seen this sort of problem before, and I think it will eventually be resolved. Posting about it here is a good start.
