Good news. Install date was moved up from next Fri to next Wed. Yeaaaaaaaaaaaaaaaaaaaa.
Interested in the Playon.tv thing. So I went to take a look.
Wouldn'tcha know....
This site can’t be reached
www.playon.tv took too long to respond.
I tried a couple of different links, several times. No joy.
(No need to try to fix this, just amusing)
Working fine for me:
- bos24207 years agoJunior
Is there a trick to getting the app on a Win10 laptop? I can see how to get it for my phones. I must be doing something wrong. Can't find how to authorize my laptop with Google Play.
(I don't use many (if any) apps on Win10) Use em all the time on the phone.
OK, I just got in to the Play On Cloud website. I guess what I need to do is this.....
Once that recording is complete, an .mp4 file will be ready for you to enjoy. You can download the recorded.mp4 video file from the PlayOn Cloud app onto your mobile device. We also email you a download link to the video so you can download it from anywhere onto any device or computer.
That's right. You set up the download (this is where they deduct the recording tokens from your account), and it works behind the scenes, in the cloud. You can just shut down the app and forget about it. It records in real time (it's a DVR-like thing), so a 1 hour show will take 1 hour to record. When the recording is done, you will get an email with a download link. Unless you pay for storage, the recording will only be stored for 7 days. If you lose the link or the email, you can use the app to get the email resent. If the recording is no longer in storage, you have to re-record it.
With the link, you can download to any device. I think to download to devices like iPhone or iPad you don't need the email, you do that from the app -- BirdDog will know more about this. I download from the link in the email to a flash drive.
the app for the computer is a software package. You need to buy a license for it. But be warned that the desktop version USES YOUR DATA. Only the app version doesn't. The desktop version is also very glitchy.
- BirdDog7 years agoAssistant Professor
bos2420 wrote:Put that on a USB stick, and plugged that into the back of the smart TV. Worked like a charm.
Does your TV have a special program built in that reads and plays what you have on the flash drive? I have a smart TV, and it has a USB port, as well. I wonder if that would work for me. It would eliminate me having to play the items on my HDMI connected laptop.
I should try to find a .mp4 clip or something somewhere, put it on one of my flash drives, and just give it a try. Now, to find something. :p
