You should try the following...
1. Shut down your connected devices.
2. Turn off your router.
3. Unplug your HughesNet modem from either the wall outlet or the power brick (NOT at the back of the modem), then disconnect your router from the modem.
4. Connect your desktop directly to the HughesNet modem with a LAN cable.
5. Wait at least a minute (from when you first unplugged the modem), then plug your HughesNet modem back in.
6. Wait at least five minutes so that the HughesNet modem is fully up and ready, then start up the directly connected desktop and try to go to the sites.
7. If that works, then shut the desktop back down and disconnect it from the modem. Then reconnect the router to the modem, reconnect your desktop to the router, turn the router on, wait a few minutes for the router to be fully up, then start the desktop again and retry the sites. If it works, try your other devices.
Tried that. No AOL/Yahoo. It works on all my devices when i go off Hughesnet.
Lorenzo wrote:Tried that. No AOL/Yahoo. It works on all my devices when i go off Hughesnet.
This forum doesn't automatically give an indication of who or what is being replied to, so if you're replying to a specific post, especially when it's a long thread like this one, it's best to indicate what that post is, whether by quoting the post, like I did with yours, or just typing what it is you're replying to, like in a letter. To quote the post, first click reply in order to start the reply to it, then click the quote button on the upper right of the message body. You can also edit the quote if it's a long one and you're replying only to a specific part.
You can also type the @ symbol, which will bring up a list of those involved in the thread, and you can click the name of the person you're replying to in order to add their name as a tag, like so... Lorenzo. This will not only give an indication of who the reply is meant for, but it also gives the tagged person a community notification that you've tagged them. They'll also get the extra email notification (the first indicating the reply to the thread they're subscribed to, and another indicating that they've been tagged). If you get email notifications from this community, you'll see two from this reply for those reasons.
