billgeyer
5 months agoSophomore
Dish knocked out of position
Good day everyone. Yesterday I ran into my dish, knocking it over about 20 degrees. I straightened it and set it plumb with a level. Now the system won't work. On the modem, the system light is off. The receiver light is on constantly, and the transmit light is continually on but flashes now and then. So I may need a tech to come set things right. What do you suggest I do?
The tech came and repointed the dish and straightened it too. I warped it when I hit it.
- billgeyerSophomore
Glad to hear that was fixed!
Call the 800 number and ask for a tech. I hope this gets solved quickly for you.
Will do, thanks.
