DNS settings question for Mark, Corrosive, BirdDog, or whoever else might be able to help...
I use a Netgear router with my HT2000W. I have the WiFi in the HT2000W disabled, and run everything through my Netgear router, which is, of course, connected to one of the LAN ports on the back of t...
MarkJFine
7 years agoProfessor
If you set the meter(s) to find 192.168.0.1 as the default modem address it shouldn't be an issue either way. It's only when you set the meter's modem address to the named one (I forget it offhand, something like www.systemcontrol.com) and the DNS is not set to Hughes' is when the meter gets weird.
I've never had any issue with the meter, even when I had the HT2000W set to Google's DNS and didn't use the Netgear router.
The meter's default setting is 192.168.0.1.
Again, though, if I set the Netgear router to Google's DNS (and the HT2000W and all devices to automatic) will the four things use Google's DNS since they are all going through the router?
