macsretandme
9 years agoNew Poster
My problem is that about 5 days ago, out of the blue, my internet connection started dropping connections to the gateway. Based on the gateway address I believe it's out of Salt Lake City. I've veri...
Good morning macsretandme,
Edit:
9 years agoDistinguished Professor IV
macsretandme wrote:there my acct # is taken off the images. now can i get some help?
You go out of your way to help keep someone safe on the net and what do you get? You get snark. SMH.
macsretandme
Did not mean to offend earlier, just extremely frustrated.
That's understandable.
