Good morning macsretandme,
Edit:
the "cycling" I'm referring to seems to be a pattern of connection/association with the server in Salt Lake City. Connection performance will be absolutely fine, start declining, out altogether, then suddenly restored all in the same web browsing session and repeating the problem pattern about 10 - 15 minutes after continuing browsing. Almost like a looping effect. Everything I can think to test on this end with equipment checks out fine. Running windows 7, Firefox Browser 57, Netgear wireless router, all operating normal, even when eliminating router, the problem persists. My modem is an HT1100 Gen4, not ready to commit to Gen5 w/2 yr contract. Disconnecting the modem from the power/computer and starting fresh does not correct the problem.
Thank you for the clarification, I will include this in my escalation report. Once I have an update for you I will post back.
