Gen 5 FAP Speed not 3 Mbps
No problem, I will PM you :)
Hi, I just wanted to do a 3 week update and it's good news. I was upset because FAP mode was virtually unusable.
It does seem like I'm getting the throttled speed pretty reliably. It has been good enough that I haven't bothered with the speed tests. I am now able to stream Netflix at decent quality with no issues in FAP mode at peak usage hours. It does have to buffer for around 30 seconds for each video and starts with low quality but it streams straight through and the resolution improves in the first few minutes. Browsing is slightly improved too. This is after the technician visited and replaced my radio and dish and ensured correct orientation. My signal strength went up from the 60's to the 90's and sometimes over 100. That technician visit was prompted by another thread about reduced performance during peak hours.
So thank you to the moderators and Amanda for addressing my frustrations with seriousness and expediance; I am much more satisfied with Hughesnet's service now.
- 12 months ago
