Damian-
I see my performance is great 🙂
02/12/2024 07:43 AM320851554YesThanks 🙂
Damian- Thanks for your reply. Most recent speed test show 455 kps just now. When was the ground station changed? if on Saturday, that adds to the mix, or not. If the signal quality, I expect this is a test of the upload strength, which indicates good aim, this does negate the aim question. What could then be the issue? Water in the connection? It appears Monday we will have clear skies, hopefully no issues with the Rapid City, SD. station for this re-association. Can we set up a time for this re-association ? I am in PST so we will be on the same time . Thanks.
My Speeds of late, last nite in lite rain were unusable. When my Gen 6 was installed, it was raining, in the days after installation , there was rain, yet I had 12mps and better speed.
Damian- what does a re-association entail? must there be noone using the system during this process?
How long does this take? Thanks
- Damian2 years agoModerator
eco,
It only requires you keeping the modem plugged in and it takes about 20-30 minutes. If you are using the system during the re-association, you will be kicked off temporarily. We can set it for Monday if skies are clear and there is no rain. That is, if you do not want to call to have a tech out to test your water connection theory. As far as what is wrong with the system, that is unclear currently. If the re-association fails, then that will rule out any and all remote fixes I can perform specifically and a tech would need to come out. Alternatively, the case could also be escalated to our engineers.
-Damian
- eco2 years agoSenior
Damian- Thanks for your info. Saturday has a clear forecast, Monday is mostly sunny. Your choice. If Saturday isn't good for you, then Monday ? After that, the techs option, then a service visit as I understand from your reply. I'd appreciate it if you'd let me know. Thanks
Damian- I hope the re-association is done on Monday. The performance lately is no, many sites time out , and sometimes a reconnect wifi helps , but fleetingly, then back to time out. My Hughes speed test results show before problems- 20mps, then after Feb 5 .....
Damian-
That's certainly a jump in speed, that's for sure.
Yes. Damian said he would perform re association. I assume this was done. The ground station was changed to Rapid City SD. Perhaps this was the cause?
Though I can't say for sure, being that it's now much better on the new ground station that's probably why.
The answer would be the day the ground station was changed, I had good speeds until 2.5 . Also why didn't the administrators re-associate my system when that happened, perhaps because of weather concerns?
eco,
I am so glad this worked and yes I was able to perform this. I assume the reason they didn't do it last time is because any bit of cloud coverage or bad weather in the area prevents us from doing that. Also, your ground station changed when you were installed on the new Hughesnet system. -Damian
Well, The install was on 1.13 , I lost performance on 2.5 , I had 12 mps and better after the install to 2.5, never above 16 mbs , it was raining the day of the install, and on and off clouds thru 2.5 when I lost speed , curious, I understand no re-association on the install day due to clouds. Perhaps a suggestion from the installer that he could not re-associate until the weather cleared would of been good, for future reference, being the dish , modem was replaced , I would think some type of association had to be done, almost an all new install, to a new bird, only the mast and coaxial cable was reused. Anyways, I'm good , a recent speed test on testmytest - 26.8 mbs Thanks Damian 🙂
