Damian-
I see my performance is great 🙂
02/12/2024 07:43 AM320851554YesThanks 🙂
Damian- I hope the re-association is done on Monday. The performance lately is no, many sites time out , and sometimes a reconnect wifi helps , but fleetingly, then back to time out. My Hughes speed test results show before problems- 20mps, then after Feb 5 .....
Damian-
02/12/2024 07:43 AM | 32085 | 1554 | Yes |
Thanks 🙂
That's certainly a jump in speed, that's for sure.
- eco2 years agoSenior
Yes. Damian said he would perform re association. I assume this was done. The ground station was changed to Rapid City SD. Perhaps this was the cause?
Though I can't say for sure, being that it's now much better on the new ground station that's probably why.
The answer would be the day the ground station was changed, I had good speeds until 2.5 . Also why didn't the administrators re-associate my system when that happened, perhaps because of weather concerns?
- Damian2 years agoModerator
eco,
I am so glad this worked and yes I was able to perform this. I assume the reason they didn't do it last time is because any bit of cloud coverage or bad weather in the area prevents us from doing that. Also, your ground station changed when you were installed on the new Hughesnet system. -Damian
Well, The install was on 1.13 , I lost performance on 2.5 , I had 12 mps and better after the install to 2.5, never above 16 mbs , it was raining the day of the install, and on and off clouds thru 2.5 when I lost speed , curious, I understand no re-association on the install day due to clouds. Perhaps a suggestion from the installer that he could not re-associate until the weather cleared would of been good, for future reference, being the dish , modem was replaced , I would think some type of association had to be done, almost an all new install, to a new bird, only the mast and coaxial cable was reused. Anyways, I'm good , a recent speed test on testmytest - 26.8 mbs Thanks Damian 🙂
