Slow Speed
I am having a speed problem. I am getting very slow speeds and have speed tested on testmy.net with an average 0.2 Mbps / 0.4 Mbps. I have i Windows 10 Pro system, 20Gb ram, and am directly connected to the modem with a new cat 6 cable. The system is up to date and uses Bitdefender Total for antivires and firewall protection. I use Superantispyware for malware and it showes clean. This has been going on for a couple of months but recently became very slow. I also can't access the WIFI settings in the modem, it previously worked but now won't accept the "admin" password. any suggestions?
Good Morning Liz,
Maybe it's a dish misalignment...the HN reps on this site can run remote diagnostics to see how everything is working. Not sure what to tell you about the password...I hope someone else here will have some ideas.
- RiverDogSophomore
Dish alignment was one of the possible problems or it could be the modem. This has been operational since Jan 2018. I was a network admin for many years, things break...
Things sure do break. The admins will be able to run remote diagnostics and you can go from there. I hope you hear soon.
- LizModerator
Good morning RiverDog,
Thanks for reaching out. I tried running diagnostics on your site but can't communicate with the modem. Do you occasionally leave the modem disconnected?
- RiverDogSophomoreI normally never shut it off. we did have a few storms come through last night, possibly that was when you attempted to access the modem. Today is clear and sunny.
- LizModerator
Thanks for the clarification RiverDog. I ran the diagnostic right before posting a little over half an hour ago. Tried running it again now and still can't reach the modem. I can dispatch a complimentary tech at the earliest available slot to review your site and address any issues. Do you have a preference for morning or afternoon visits?
