Intermittent internet loss Status code 12.7.1 A transmit problem has occured
Good morning,
The fix was rolled out this morning on beams 21 and 29. Please monitor your performance over the next few days and let me know if you see any significant improvement.
Hi Michael,
You're very welcome. Please check your PMs and feel free to come back to the community if you need anything or would like to help others.
Liz wrote:Good morning,
No outages since the fix on Friday. Even with overcast skies, light rain, and at times dense fog. All is well. Thanks again.
MSmith wrote:Sunday 3/19
Down once again at 10:55 through 11:03 am. Same code, clear skies.
Check the skies at your gateway. Often the weather at the gateway influences your access.
I have no information about where my gateway is. Can you point me to it?
Check your system control center a http://192.168.0.1. Look for the Gateway ID number under System Information.
ETA: Here's a list (it's not complete, though)
#1: Salt Lake City UT
#2:Albuquerque NM
#3: Amarillo TX
#4:Billings MT
#5:Midland TX
#6:Flagstaff AZ
#8:North Platte NE
#9:Missoula MT
#11:El Paso TX
#12:Tucson AZ
#13:Rapid City SD
#14:Edmonton, Canada
#15:Regina, Canada- MSmith9 years agoSophomore
maratsade wrote:Check your system control center a http://192.168.0.1. Look for the Gateway ID number under System Information.
#2:Albuquerque NM
#3: Amarillo TX
#4:Billings MT
#5:Midland TX
#6:Flagstaff AZ
#8:North Platte NE
#9:Missoula MT
#11:El Paso TX
#12:Tucson AZ
#13:Rapid City SD
#15:Regina, CanadaGood enough. The skies look clear in Flagstaff. Thanks
Loss of service again.
3-19-17 at 3:12-3:26 pm code again 12.7.1
also 8:18-8:26 pm code changed this time to 12.1.9 Still states A transmit problem has occurred.
