Intermittent internet loss Status code 12.7.1 A transmit problem has occured
Good morning,
The fix was rolled out this morning on beams 21 and 29. Please monitor your performance over the next few days and let me know if you see any significant improvement.
Hi Michael,
You're very welcome. Please check your PMs and feel free to come back to the community if you need anything or would like to help others.
Liz wrote:Good morning,
No outages since the fix on Friday. Even with overcast skies, light rain, and at times dense fog. All is well. Thanks again.
Hi MSmith,
Thank you for posting and providing ongoing updates. I ran diagnostics on your site and I'd like to send you a replacement modem to see if that will make any difference in your experience with intermittent connectivity. You should receive the modem in the next couple of days, and you can use the box it comes in to return your current modem. The return label is included in the outer pouch for your convenience.
Looking forward to hearing how the modem works out for you.
- MSmith9 years agoSophomore
JerryJ wrote:
I have the same problem this guy does, and have had it for a month. I've made 3 calls to your help desk, and had a repairman here. He tested my equipment and it tested fine. He said the problem is with the Jupiter satellite and that a fix was imminent. I hope this issue is resolved soon. Msmith let me know if the new modem resolves the problem.Will do.
Lost service this morning while reading new posts. It went down at 5:31 and came back at 5:39. Same code once again. 12.7.1 A transmit problem has occured.
- ArkanDan9 years agoNew Member
Up and down like a yo yo each morning for the last week or more. Around 07:00 to 10:00 as far as I can tell. Annoying and no notice from Hughes that they've got a problem and are addressing it. My location is NNW Arkansas. Good weather ot bad.
- Liz9 years agoModerator
Hi Michael,
In case you missed it in John's thread:
Our engineers confirmed a timing issue affecting your beams, 21 and 29. A fix for this has been recommended to the network engineers, but the implementation date has yet to be determined. Once I get word on when this will roll out, I will let you know.
Thank you again for providing details, this helped us greatly. I'll keep you posted.
