Link speed
Hi Nathan,
When you say "link speed" are you referencing a certain test result or your local LAN link speed? Both 72Mbps and 54Mbps are off the charts high for Gen4, so it would be good to get a little more information.
- BirdDogAssistant Professor
If you can't stream at those speeds then you have another issue going on. The advertised speed is "up to" 25 Mbps so you are way above that.
Both those speeds are way above the norm and may not be accurate. What test are you using to measure speed?
- AmandaModerator
Hi Nathan,
- nathangilbertFreshmanI must be looking at wifi link speed. Just ran a speed test and came up with 17mbps
What is the result you get when you run the test in the following link? http://192.168.0.1/limited.html#!/general/lan_speed
