problem accessing podtrac.com
I'm reliably informed that this wget works when run through another ISP. I might add that from my system, accessing other podcast providers works OK.
wget --no-check-certificate -vvv -O ml https://www.podtrac.com/pts/redirect.mp3/pdst.fm/e/chtbl.com/track/8G441/traffic.megaphone.fm/WWO7230198885.mp3 --2021-04-29 08:48:06-- https://www.podtrac.com/pts/redirect.mp3/pdst.fm/e/chtbl.com/track/8G441/traffic.megaphone.fm/WWO7230198885.mp3 Resolving www.podtrac.com (www.podtrac.com)... 54.200.97.37, 52.24.105.221, 44.231.197.162 Connecting to www.podtrac.com (www.podtrac.com)|54.200.97.37|:443... connected. HTTP request sent, awaiting response... 302 Found Location: https://pdst.fm/e/chtbl.com/track/8G441/traffic.megaphone.fm/WWO7230198885.mp3 [following] --2021-04-29 08:48:11-- https://pdst.fm/e/chtbl.com/track/8G441/traffic.megaphone.fm/WWO7230198885.mp3 Resolving pdst.fm (pdst.fm)... 216.239.36.21, 216.239.34.21, 216.239.32.21, ... Connecting to pdst.fm (pdst.fm)|216.239.36.21|:443... connected. HTTP request sent, awaiting response... 302 Found Location: https://chtbl.com/track/8G441/traffic.megaphone.fm/WWO7230198885.mp3 [following] --2021-04-29 08:48:15-- https://chtbl.com/track/8G441/traffic.megaphone.fm/WWO7230198885.mp3 Resolving chtbl.com (chtbl.com)... 13.249.48.69, 13.249.48.62, 13.249.48.37, ... Connecting to chtbl.com (chtbl.com)|13.249.48.69|:443... connected. GnuTLS: Error in the pull function. Unable to establish SSL connection.
Looks like an SSL error, which may mean the DNS cache is corrupted, which happens time to time. Try rebooting the modem to clear the DNS cache.
If that doesn't work, it may mean the corrupted DNS entry may have propagated to the device you're trying to reach Podtrac with. In order to fix that, you generally need to refresh your device in a manner that doesn't allow the corrupted entry to re-propagate over the LAN:
1. Turn your device(s) off.
2. Remove from the modem at the wall socket.
3. Wait 60 seconds and re-power the modem.
4. Wait another 60 seconds until the modem has fully rebooted and turn your devices back on.
- MarkJFineProfessor
- Geoffrey LeachSophomore
Problem solved. Thanks.
