bkeeper1
9 years agoJunior
Problem AGAIN with speed in evening!
.68 on your test a few minutes ago. Very slow in evening below 1.0 at times -- buffering, etc. check testmy site and your site the last couple of days. Speed acceptable in morning. I know traffi...
bkeeper -our last discussion ended with upgrade and cancellation options. I have private messaged you about upgrading and what I can do for you.
bkeeper1
9 years agoJunior
Good morning Amanda;
Did not notice much of a change -- speed seems more erratic. Dropped to less than 1Mbs last evening. Check out the testmy page. I was trying to stream movies yesterday so that might have influenced the tests in the afternoon and early evening. But tests run later were isolated. We will see what happens over the weekend. I think they still have work to do.
One thing else I have noticed. I have not been getting the daytime speeds I used to get. (I believe I mentioned this before) I used to get 15 to 20 Mbs regular, now I,m lucky to get 12 or better. Don't know if this has a bearing on the problem or not? Like right now, it is 4-5 a.m. and I am only getting 7-11 Mbs. Should be much higher. Everything is off here, and there can't be much traffic.
Thanks for your help,
Clff
Clff
