Problem AGAIN with speed in evening!
bkeeper -our last discussion ended with upgrade and cancellation options. I have private messaged you about upgrading and what I can do for you.
Hope you had a good weekend. It has been pretty much the same here (with the connection speed) as it has been lately.. Sure hope this gets fixed soon. I have been running a lot of speed tests - so you can check those out on the testmy page.
Cliff
- bkeeper19 years agoJunior
Have not heard from you. Still having same problem. What is happening? When is the new one going online or whatever? Would appreciate knowing you are still there.
Cliff
Hi Amanda;Problem is getting WORSE - STILL NO SPEED IN EVENING!! I know you are busy - what with the changeover etc., but would appreciate it if you would at least wave as you go by. Any idea how much longer this is going to be? It is really getting old. Keep smiling -- things have to get better (I hope).
Thanks for your help
Cliff
.- bkeeper19 years agoJunior
Another bad weekend. Wife says to have patience, but I am getting tired of the slow speed. We have been downloading (a lot of) movies during the times when the speed is somewhat acceptable, so that we (have a choice) (can watch them) all the way through without the constant buffering. BUT this means that I have exceeded the expected usage for this data cycle. Thank goodness I had a backup of tokens. It will all work out. I am not giving up on Hughes and you yet. Any idea of how much longer? You must have quite a mess right now. Smile, it could be worse.
Cliff
