MODEM
MODEM
MODEM
MODEM
Hi DocT,
I see it's your first post here, so welcome to the community! Thank you for the useful information, this helps. I ran diagnostics and the equipment looks fine. I've escalated your case to our VOIP team to see what we can do for you. I'll reach out when I have an update to share.
- DocT8 years agoFreshman
Thanks for the quick reply. Let's see if we can make it work again!
I haven't heard from the VOIP team.
Last night, our first call was dropped after about 12 minutes. The phone began ringing repeatedly as though the person we were talking to was trying to call back (she wasn't) and when we would answer, the line was dead. Hang up. Repeat. I turned off power to the ATA to make that stop. After that, we could make a call and it would last a minute or two before disconnecting.
I hope to hear from the VOIP team soon. We have no cell phone signal at home, so we can't really call customer service.
- Liz8 years agoModerator
Hi DocT,
Thanks for the additional details. Our corporate VOIP team isn't going to reach out to you, I only just escalated your case yesterday after you posted in the community. I will post back once I have any updates from the team.
