MODEM
MODEM
MODEM
MODEM
I'm getting a "directory not found" on the second link.
In any case, I didn't really follow those directions (although having that document around would have been useful last week). We signed up through a local distributor in Houghton Lake, MI and they did the installation. Our previous system (Exede) had a modem with only one LAN port, so carrying the internet signal through the ATA to other devices was the only way to go.
The directions on the first link look fine to me, and quite clear. Perhaps our local distributors need a refresher!
t
Wow! ok good to know! Thank you! Glad it's all sorted out now. Feel free to drop by again if you need anything else.
Have a good rest of your week!
- Robp18 years agoJuniorThe last call to HughesNet was a bit heated as they still had not fixed anything. Finally a rep from account management looked through all the problems, and had a tech out to my house in less than 48 hours. Clayton was excellent, he had the problem diagnosed and fixed in two hours. The original install on the dish was done incorrectly, the ground wire was faulty, the dish was all over the place, and the coaxial wire wasn’t installed correctly. Clayton made sure everything was in place, realigned, and up to 100% before he left. It’s been a few days MY PHONE HAS NOT DROPPED A CALL and my internet is WORKING! A big shout out to the The team, I really can not thank everyone enough!
- Jay8 years agoModerator
Robp1,
Thanks for the update! We're glad to hear that your issue has been resolved and that you had such a great experience!
Thank you,
Jay
