Intermittent connectivity, 12.1.9 and many other state codes :-(
Hi there Mommabird!
It looks like over the past few months the antenna has steadily gone out of alignment, or the line of sight has degraded. I see from the last visit that the line of sight is adequate but I can see how some growth on the tree would impact the service. Generally, leaf or plant growth shows itself by a declining signal over time - exactly what I see on my end. I can send a technician out, but in the next year or so it may happen again. I recommend having the tree trimmed.. or the way my mother used to do it - a rope hugging the branch(es) and tilting them away :)
The site visit will be free of charge and someone will contact you to confirm the visit date and time.
Thank you! I will wait to hear from someone!
Mommabird wrote:
Our dish is mounted on our roof. We had a big snowfall just before this happened, and at first I thought that snow sliding off the roof may have bumped the dish enough to have it off-target.............
I've always avoided mounting anything on my roof. Just a leak waiting to happen IMO. Cost a little more to
put it on the ground, but I'll gladly pay the difference. Plus it's a lot easier to work on if it's on the ground.
If it is an alignment problem, I'd consider moving the dish off the roof.
I live in Florida, so I never have to worry about sliding snow. Maybe another good reason not to have a dish mounted on the roof.
We live in the mountains of western NC surrounded by forest. Nothing short of putting it on the roof would give the dish a view of the sky :-) Dish was formerly post-mounted, trees eventually blocked path to satellite. Roof is last resort.
- gaines_wright7 years agoTutor
Mommabird wrote:We live in the mountains of western NC surrounded by forest. Nothing short of putting it on the roof would give the dish a view of the sky :-) Dish was formerly post-mounted, trees eventually blocked path to satellite. Roof is last resort.
Ah, I know a little about the area, many people had to have a four wheel drive just to get up their driveways. Good luck on getting the dish to work on your roof, otherwise you may have to cut some trees. Well, you could probably use the firewood. When I was in that area, everybody had a wood stove or a fireplace.
I've had my DirecTV dish on my roof since the Spring of 2005. No leaks and no issues, other than it being a bit of a pain to reach in order to brush snow off of in the winter, and this is with an extension pole.
GabeU wrote:I've had my DirecTV dish on my roof since the Spring of 2005. No leaks and no issues, other than it being a bit of a pain to reach in order to brush snow off of in the winter, and this is with an extension pole.
I hope you knocked on wood. It'll probably start leaking tomorrow. :>)>
Seriously, I was advised many years ago, by an several people that I knew, with years of roofing experience, not to put anything on your roof. I live in Florida, where the sun is really tough on roofing materials. I have a 26ga galvalume roof on a 6/12 pitch that was installed in 2004. About 2014 I had to have all of the roof penetration boots replaced.
Haven't had any trouble with snow though.
- 11 months ago
