No speed, loses connection, buffers continuously
tech cme yesterday an repointed my satellite, It is still getting varying spins but they are between 14 and 33mps, The 14mps was durging rainstorms yesterday. So far it looks good. Thankyou for all your help and I am closing this thread as solution and see how it goes
The links you're providing aren't working properly, as you can see in your replies. That's okay, though, as the reps only need the link to your Results page, and it only needs to be posted one time, as it always shows all tests that have been run thus far. I'm 99.9% sure that the link I posted is to your tests, as I see that the proper test sizes are starting to be used.
So that the reps know for sure which test results are yours, please verify if the test results in the following link are yours. Again, I'm 99.9% sure that they are, but I want to be 100% sure, for the rep's sake.
Good afternonn. I called tech at Hughes. He did increase the speed to about 14 mps with some ups and downs. This morning it was 3.1. as of noon today it is about 11mps. the tech i talked to gave me a case number and said he was sending to Hughes net tech and they would contact me. I haven't heard from then yet. I was talking to Hughs tech support so maybe he is sending it up the chain. I am still checking the speeds several times a day. Thanks for helping me out with this.
