Slow or dropping connection
Good morning MrCRJP,
Thank you for all your updates, glad to hear the service is working better now. I've escalated your case to our engineers here at corporate to ensure the same concerns don't pop up again later. I've also sent you some free tokens for the troubleshooting efforts, so you may receive an e-mailed order confirmation for the complimentary tokens.
If you do encounter anything out of the ordinary, please note the state code you see at the time so it can help us focus our efforts.
Thank you for the tokens and the resolution here. I'll be sure to post again if anything changes. I think GabeU might be on to something about our location being on the transition point between two beams. Thankfully, the new gateway seems to be doing what we need.
In response to MarkJFine, the power supply is something I don't quite understand about satellite modems. When we first had our install done, the installer was hesitant to connect the power supply to our UPS. I didn't understand this; Shouldn't a UPS or filtered power strip provide stability against the power variations which would otherwise cause problems? Plus, our UPS produces a true sine wave when it switches to battery.. If it was the more blocky DC/AC conversion of a conventional UPS, I could understand the problem. Either way, we operated just fine on the UPS for 14+ months until this problem cropped up.. Ironically, when I pulled the power supply from the UPS and connected it directly to the wall outlet!
We also have some tree limbs which might now be starting to cause a problem, although there are no leaves on the limbs any more, of course. I may look into doing some additional trimming in the spring just to eliminate this. We took down about 10 trees this last spring to clear the skies for our Dish service!
Again, thank you to everyone who has replied. I'm going a bit verbose here in case any other customers stumble across this thread, so that maybe they can glean a solution from it. :)
- 4 months ago
