Satellite Receive Signal Strength
- 5 years agoGabeU...
Thanks for the advise and help.
Thank you for running diagnostics on the site. I'm not surprised you found no problems, why I wanted to wait till the signal went low. This morning the SRSS, Satellite Receive Signal Strength, is at 121. If the SRSS stayed that way, except for normal causes, which I have already talked about in this thread, I would have no issues on this subject, a very good SRSS to say the least for anyone. But if pattern holds it will unfortunately repeat again. Intermittent problems are very difficult to track down and identify.
Stevie - 5 years ago
He redid the connections and removed an extra interconnect I was unaware of. After powering up the modem SRSS was at 70. I was very happy to see the problem had reared its head for the tech to see.
He replaced the receiver and redid the ground connect. He then went through a realignment of the dish and discovered the dish itself was tweaked preventing best signal. The main dish assembly was put in service about July 2009 when I first became a customer. He replaced the dish assembly and put on the new receiver and realigned. He said he got a signal of 140 now.At the System Status page I got a SRSS of about 102, about 10:30 in the AM. That's about right for the signal for when I first upgraded to Gen 5. It would average, with no weather, 95 -105 or so. So that works for me.
Thank you all for your support,
Stevie
Good morning sanderlay1,
Thanks for posting. I ran diagnostics on your site-- all is running normally and there's nothing of significance we need to address. Of course, should you encounter any performance issues in the future, feel free to reach out again so we can have a look.
Stevie
