Starting at 6AM on Saturday started acting right, but last night at 4AM(Monday morning) a storm came through, knocked out my internet for awhile of course, and when it came back its doing this extreme slow speeds
Based on the three 12-25MB download tests ive done, speeds are at 40KBs which I believe is abnormal, and I can barely run any website while its acting up like this. Computer is directly plugged into the modem, WiFi is deactivated. Ive used multiple browsers on this computer, and ive tried another computer and a Nintendo Switch, all with the same results
But obviously its a transient problem. Is there any information on the Beam still being heavily overloaded, or some other kind of issues? I'll edit with my speed tests in a few, its taking awhile but I wanted to have some time between them. I forgot about the special download speed, and over Saturday and Sunday I had done the standard tests. Further more, im on total throttle now, no data for regular times or the bonus zone, but I was in that state all of Sunday and it ran well, speeds on a download showing up as over 200KBs
https://testmy.net/quickstats/DanKaiser
Got the quickstats, I'll do a couple more download tests!
It's likely the weather interfering with the signal.
EDIT: When the issue is taking place, please post the modem's state code, which can be found here: http://192.168.0.1/#!/home/status
- Danny895 years agoJunior
Can't be the weather, thats already gone and there was no storms when this started last week.
Right now my state code is 24.1.1 Download Throttled. Satellite recieve strength is 105- maratsade5 years agoDistinguished Professor IV
The 24.1.1 code means you've exceeded your monthly data and that your speeds will be throttled until your data resets. You can also buy tokens to reset it before that.
If you have bonus data left, your speed will be normal during bonus time (2 am to 8 am your local time).
Oh, I know. Ive just never had a throttle so hard that it has literally made me incapable of using the internet. AND most importantly, I had data when the problem first began, I didn't run out of Data until later on Saturday
Obviously that mega speed test would be the one for when I still had data, and the problem had resolved itself for Saturday
- 11 months ago
- 11 months ago
