Aedan wrote:
What just happened didn't just happen to you. It did the same thing to me. Everything is back up now.
Something may have happened to the system and it reset to fix itself.
Ah. Okay. Thank you. I figured it was something technical, as when it's been out due to a storm over the years it's acted a bit differently, with the signal strength being all over the place, and the system pretty much working immediately after that signal was back up to "strong enough", but not this time. Plus, I know that my gateway is in Roseburg, OR, and there was nothing going on anywhere around there at the time.
Oh, wait. Can I get a three cent offset for the month, due to it being down for a half hour? J/K!!! :p
- arceus2139 years agoSophomore
- 10 years ago
