Slow or dropping connection
Good morning MrCRJP,
Hi MrCRJP,
I'm glad you found the community, thank you for posting the steps you've already tried so far. I'm running diagnostics on your site right now and so far, so good. I do see the 30.1.1 state codes in your history and am seeing that there was something that happened on your gateway over the weekend that seemed to have caused this. Let me escalate this to our engineers for their input. I'll post back once I have any news to share, instructions, or questions for you.
Thanks again for your help!
The gateway Liz is speaking of is the gateway for your beam. The signals from your spot beam, and a few other spot beams, are routed through a specific gateway, which is located in a state that is different than yours. The gateway is where your service actually enters the internet. I'm in NY, but my gateway is located in OR.
When you reboot your modem it can put you onto a different "channel" within the beam, which can sometimes fix, at least temporarily, minor issues.
Here's a rough graphic regarding the gateway...
- MrCRJP7 years agoFreshman
Yeah, I feel a bit silly having used that term.. I was thinking of it in terms of the gateway as viewed by a client inside the LAN. I'm thinking the gateway in your diagram is the one running BGP. :)
This morning, the connection seemed to be OK, but then it fell apart again. I needed to go back to the IP address of the modem rather than systemcontrolcenter.com, since the modem had also apparently lost its DNS mind as well. Is there a chance that doing a factory reset on it might clear up the problems?
- Liz7 years agoModerator
Thanks for this update, I just cleared the modem's DNS cache. Let me know if sites load properly now. (Doesn't hurt to flush your computer's DNS cache as well).
- 6 months ago
