Slow Speed
Good Morning Liz,
I never finished using the desktop system. It would get a little less than 2 MB and just quit working. i've waited over 20 minutes and there was no change. I hocked my laptop up and ran 4 tests at 25MB. I averaged from 14.85 to 8.32 MB. this tells me there is something in the desktop not working right. I still think there are other problems, possibly in the modem since I can't access the WIFI area. I could also be alignment. let me see if I can see what's happening on this end and leave the ticket open. Unless i hear from you it will probably be a couple of days or so. Here's a link to my last test results.
https://testmy.net/db/yfwWzfbHc
Thank you,
Good you were able to discern that something may be off with the desktop computer.
As for accessing the wifi settings, if admin is no longer working you can try these steps to reset the modem and wifi password:
-Simultaneously press the reset button in the back and the WPS button in the front.
-Release the reset button, don't hold it down.
-Keep the WPS button held down for 30 seconds or until any LED other than Power comes back on.
You should now be able to log into the wifi settings of the mode using the default credentials on the back of the modem.
- RiverDog5 years agoSophomore
Good Morning Liz,
- Liz5 years agoModerator
Good morning RiverDog,
That's amazing! I like your logical approach; so happy you found the culprit! Thank you for the kind words, and I appreciate your understanding. Have a great Friday and rest of your weekend!
