Good morning everyone,
Thank you,
Could be a corrupted DNS cache causing this.
You may want to consider disconnecting power to the modem, and your third party router, then change the DNS provider to Googles DNS. Once you have done that, you may want to flush your DNS records on your computer.
If that doesn't work, you may want to change your DNS server on your computer back to Automatic.
Was just about to also suggest it might be a DNS problem.
I've also had a problem where Amazon wouldn't load in the past. Rebooting the modem and any other external routers fixed it right up.
- Amanda9 years agoModerator
Thanks for all the replies! Can those with the issue give rebooting the modem/router a try? If that doesn't work, let me know. I am still waiting on an engineering reply.
~Amanda
- theoverlook19 years agoNew Poster
Having the same issue here; rebooted the modem, same issue on various devices and browsers, nd only affecting Amazon.com
