Good morning everyone,
Thank you,
Personally don't care for the HughesNet DNS servers, I use the Google public ones, 8.8.8.8 and 8.8.4.4. No idea if anything to do with the problem but throwing it out here. Have'nt had this kind of problem for a long time since I switched servers.
BirdDog wrote:Personally don't care for the HughesNet DNS servers, I use the Google public ones, 8.8.8.8 and 8.8.4.4. No idea if anything to do with the problem but throwing it out here. Have'nt had this kind of problem for a long time since I switched servers.
For me, very oddly, and still, the problem doesn't seem to crop up nearly as much when using Hughesnet's DNS. Normally I use Google's, but on a whim I changed it back to Hughesnet's just to see what would happen, and since doing so I haven't had the problem pop up nearly as much. Just once or twice since changing, whereas usually it would happen more often than not when going to Amazon. That's not a joke. It was awful.
With that said, though, my issue may be a little different than the OP's, or even others that are posting, as when I would have the problem the page wouldn't load at all. It would give me an error. This is with a desktop using Windows 10 FCU and Chrome. But, as to why Hughesnet's DNS seems to work better for me, at least when it comes to Amazon, I'm stumped, as Google's should be the one to work better when going by the general success rate between the two.
Here's what I see when it happens, and again, no joke, it used to happen more often than not. This problem started for me about four months ago. But, with that said, I changed back to Hughesnet's DNS around the time of the W10 FCU, so that may have something to do with it, too. The following is a snapshot from a few weeks ago.
Two different things, yet related.
One is where the site couldn't be reached (main URL https://www.amazon.com didn't resolve).Other is where one or more of the stylesheets couldn't be downloaded (css URL https://images-na.ssl-images-amazon.com didn't resolve) to render the main page correctly.
It's interesting to note that once in a while I'll see the same type of issue the OP and others are seeing when I go to Walmart's site. The page will load, but it will be thoroughly messed up, with text and links often all down the left side of the page and no pictures loading. This has actually been happening for a few years with Walmart, and I've always assumed it was their problem, not mine, as I've never had the same problems anywhere else.
Just the other day they lost a sale from me because their home page was doing this.
I've never been a Walmart fan, but not the reasons you state. I've stepped foot in one out of necessity just once.
- RAL8 years agoNew Member
For what it's worth, have similar problem with Amazon. After having spent quite a bit of time trying to resolve it, including powering the satellite modem down, then up again, with no success, someone in this thread mentioned the "reset" button on the modem. So, having tried a lot of other things and even after having powered it off then on with no success, I did use the "reset" button on the modem and somehow that fixed the problem. Don't know for how long, but at least it's clear where the problem resides. Just for info.
Jesus... They need to remove that reset button, or hide it, or change it's functionality. It's not fixing your issue.
- pateleighton8 years agoSpectator
We're having the same issue with Amazon as others. Going to try to reboot the modem, etc. Will report back.
Please do not utilize the reset button unless instructed to do so by a tech or rep. Doing so can cause more harm than good, and harm that may require a tech visit to fix, of which you would be responsible for paying. Again, please leave the reset button alone.
pateleighton wrote:We're having the same issue with Amazon as others. Going to try to reboot the modem, etc. Will report back.
Rebooting the modem may help, but flushing the DNS might, as well. Make sure that when you reboot the modem you unplug it at the wall socket, not the back of the modem.
- whysalives8 years agoSophomore
Problem reoccured again today. This time I tried just rebooting the modem (from the web interface) and my laptop, at the same time. That did not solve the problem. So then I tried just rebooting the router (from the web interface) and my laptop, at the same time. That did solve the problem, for the time being.
Next time I will attempt rebooting just the router and laptop first.
I should point out that if it keeps recurring for a specific site, such as Amazon, it's quite possible a rogue site or rogue ad is likely spoofing that local DNS entry... that includes some of those embedded "mraid" ads you get in phone apps.
And, before anyone says that they can't, I'm dealing with a ad company (to remain nameless) that rotates ads through some javascript code. They didn't know that one of their ads forwards to another malicious ad that captures the site (e.g., not a popup) for a phony Amazon Gift Card that's only targeted to Apple iPhones. Two guesses what else it does, and the first one don't count...
Problem reoccured, second time today. This time I tried just rebooting the router (from web interface) and my laptop, at the same time. That did not solve the problem. I then reboot the modem (from web interface) and my laptop, at the same time.
So it appears all three need to be reboot, but no issues doing that from the web interfaces.
"Two guesses what else it does"
First guess:
It asks for personal information and access to your facebook page. It spams your facebook friends with the same ad and releases your information to third parties for "special" offers.
Second guess:
It drops the firewall and installs a keylogger.
You win 👍🏼
Though this is a little off topic, if I had all of those $50 Amazon Gift cards that I supposedly won I'd be a rich man. Every day there's another one or two in my spam, and every day it's a new domain, so blocking them is practically impossible. Still, it's somewhat comical how many I'm supposed to have won over time. Hundreds. :p
- Amanda8 years agoModerator
Hello everyone,
Just a quick update, I know I have not given one in a while here. Engineers have found the cause and I am actively tracking their progress on it. I will give you updates as I get them!
~Amanda
Now that I have a quick and reliable means of correcting the issue, I've turned my attention to the trigger, and I believe I found it.
My daughter recently started playing at AnimalJam.com.
It doesn't matter if she logs in from my laptop or the tower, either way, Amazon gets borked. I haven't a clue as to why and I'm at a bit of a dead end for what to do about it. Suggestions welcome.
Hmm, it's possible there's a rogue advertisement loading... I have adblock on and dont have the issue.
An ad blocker is what I would suggest. Just wish there was something for phones/tablets for all the mraid stuff.
I have installed Ad Blocker Ultimate from the Chrome web store. I made sure Amazon was loading properly, then logged in to Animal Jam, then back to Amazon. No issues. But here is the weird part. The chrome browser on the tower doesn't have ad blocker installed. Yet it doesn't cause the issue any longer either. In fact, Animal Jam is National Geographic and subscription based, which is to say it does not contain ads. Ad blocker doesn't indicate any ads at Animal Jam, but it does show a lot of ads blocked at Amazon. I'll have to run a couple more tests, but at the moment, it looks like an ad at Amazon was conflicting with my laptop and sharing that conflict with the router. Animal Jam was stumbling over it, but the results don't show up on Animal Jam, they show up back at Amazon.
Hrm, doesn't appear there are ads, but adblock is blocking a few things, mostly tracking cookies.
I might have to keep an eye on AdBlocker Ultimate. I have Adblock Plus, which is pretty much what's usually recommended and is used by a slew of people, but AdBlocker Ultimate looks interesting. Maybe I'll give it a try on my laptop and see how it compares.
Hi everyone,
I will be finding out more today on the status of resolving this.
On a side note, I use both Adblock Plus and uBlock Origin. I feel uBlock is very aggressive in auto-closing unwanted browser tabs before they can hijack your browser.
~Amanda
ublock is sometimes too aggressive :( Still use it >.>
