Web Acceleration failing
Hi GW,
GW,
Upon looking into some diagnostics, it doesn't seem like the diagnostic codes you're receiving should have an affect on the performance of your modem. Is the new modem working properly? I'm glad the new package got out quickly to you.
Remy
Hey Remy,
It's not doing really great but I hope it will get better. I'm getting some page load errors and it's giving my Thunderbird some problems with getting the mail.
Mid to low 80's signal is good considering we have a thick dust cloud from Africa clotting our atmosphere down here in Lower Alabammy. Ping is about average. Web response test to some server in North Carolina wasn't impressive at 4.5 seconds. Chicago was better at 2.6-3.0 seconds.
It's hanging in there with a 0.0.0 state code but throwing different diagnostic codes every hour. Odd looking codes. I hope it can settle down to the regular 0000-0000-0000-0005 like my modem. I've seen two instances of 0208-0000-0000-0005. I don't know what that one means but maybe it's getting closer to the no errors code.
It seems to be improving a bit in the RedX department. Now only showing the X for TCP and DNS (N) acceleration in the graphs. Down to a total of 12 Red X's at the moment.
It was doing some miserable DL tests of 13-15 Mbps at testmy but it's picking up a little bit now.
Dumping the reboot log into a spreadsheet for counting shows this thing has been power cycled 100 times since 1/29/19 with two boots for software upgrades. It's definitely got some serious mileage on it to go along with all the scratches and rub marks.
- GW6 years agoAdvanced Tutor
It threw lots of state codes overnight. When I woke up my computer at 5:30 AM, status is in the yellow with Web Accelleration Down. RSS is 85. Diagnostic code is 0000-0000-0000-0005. State code is 30.1.1. At 5:40 AM it's back in the green.
11.2.1 1 195 06/26/2020 04:02:18 06/26/2020 04:05:33 0.3779% 11.2.2 1 90 06/26/2020 04:00:28 06/26/2020 04:02:18 0.1744% 11.3.1 1 10 06/26/2020 04:05:33 06/26/2020 04:05:43 0.0194% 20.2.1 1 39 06/26/2020 04:05:43 06/26/2020 04:06:22 0.0756% 30.1.1 2 623 06/26/2020 10:29:37 06/26/2020 10:39:37 1.2074% Edit: The diagnostic codes are flipping all the time and it's loving State Code 30.1.1.
30.1.1 4 1823 06/26/2020 11:09:12 06/26/2020 11:19:12 3.3778% Just a note, it probably isn't the radio. That was changed two weeks ago by a technician. He replaced the old Gen4 ODU with the new version.
- C0RR0SIVE6 years agoAssociate Professor
20.2.1 and 30.1.1 makes me think congested/overloaded gateway and/or WAS... I remember seeing 20.2.1 frequently at one time back when I was on ES17 with a heavily congested beam.
Thanks for the info.
20.2.1 is listed as "A management problem has occurred"
30.1.1 is rapidly becoming the default state of operation. It's shut down again but I can hit the control and fix it.
