Web Acceleration failing
Hi GW,
GW,
Thank you for the updates. I will continue to look into this for you and will be getting back with you when I have a report with some more information on a possible fix. We appreciate your understanding and cooperation!
Remy
I truly appreciate your help Remy. I'll keep you updated. I was hoping it would get better but it's not. Terminal downtime is still increasing. Now it's 17%. 5 hours out of the last 29 hours. 28 on the Red X count.
- GW5 years agoAdvanced Tutor
Here's a little more info for you Remy.
In past day this thing went to 30.1.1 a total of 51 times for a duration of 8½ hours.
I never realized how crippled Hughes is without fully functional web acceleration. There are many tasks that simply can't be done. I sure hope this isn't a solar coronavirus breaking my beam :smileywink:
Recent diagnostic codes. The 0000-0000-0000-0005 coincides with a no Red X period in the hourly history
0204-8020-4802-0485 (10:00:00 - 13:00:00) 0000-0000-0000-0005 (07:00:00 - 10:00:00) 0204-8020-4800-0006 (04:00:00 - 07:00:00) 0204-8020-4802-0485 (01:00:00 - 04:00:00) 0204-8020-4802-0485 (22:00:00 - 01:00:00) 0204-8020-4802-0485 (19:00:00 - 22:00:00) 0204-8020-4802-0485 (16:00:00 - 19:00:00) 0204-8020-4802-0485 (13:00:00 - 16:00:00) - Remy5 years agoModerator
GW,
I appreciate you tracking these for me. Upon further investigation, it seems that these diagnostic codes won't have an effect on your services, as quite a few of them are just standard processes in the modem. In regards to the 30.1.1 that seems to be popping up, that state code refers to backing off on adding the modem to a specific web accelerator server, to avoid additional loading times. Does the service seem to be working well?
Remy
Remy wrote:I appreciate you tracking these for me. Upon further investigation, it seems that these diagnostic codes won't have an effect on your services, as quite a few of them are just standard processes in the modem. In regards to the 30.1.1 that seems to be popping up, that state code refers to backing off on adding the modem to a specific web accelerator server, to avoid additional loading times. Does the service seem to be working well?
No Remy, it isn't working well at all. I guess you missed the message I posted for you last night. The one where I say:
"I never realized how crippled Hughes is without fully functional web acceleration. There are many tasks that simply can't be done."
I think you also may have missed the part where I advised you something is nuking the web acceleration function in precise 10 minute chunks of time. Per the logs, it's happening all day and all night with the notable exception of proper operation during the wee hours. From 2 AM until 5 AM local last night and from 11 PM until 5 AM Saturday night.
Otherwise, Web Acceleration has been in a state of failure 145 times for a total of almost 24 hours since I put this replacement modem into service 4 days ago. It's getting worse and happening several times an hour now.
After being with Hughes since 2011, I'm thinking this isn't a normal situation.
GW,
I apologize for misspeaking, I was asking more of if your service is working well when the state code is not showing. The 30.1.1 state code isn't one we can manually fix, as it is connected to a Web Accelerator server not being available at the time. As soon as one is available to the particular user, you should be placed there. For a possible fix, I suggest trying to turn off the Web Accelerator and turning it back on, as this can sometimes hasten the process.
Remy
That didn't work. The only thing many resets of Web Acceleration may have accomplished is a slight slowing of the failure rate. Otherwise, no changes. No Red X's in the hourly history between 2 AM and 5 AM. Then right back to failures.
Is it the network or is it the modem?
GW,
30.1.1 itself is normally a network issue, however, seeing the rest of the state codes may be a power issue. Are the modem and cables plugged in securely? Are you connected to a surge protector, or directly to an outlet?
Remy
Sometimes it acts like it's getting better. For instance, at this moment I have all green checks on the hourly history and only 8 red x on the daily chart.
But, it really isn't getting better at all. My internet has been impaired or non-functional 36 hours out of 6 days. Some of the uplink/downlink outages are due to weather but unless I'm getting cut off by bad weather up at the gateway end, not very much.
Yes, all power is clean and good with no recorded noise at all lately. Only a few blacks but no browns or overvoltage. All connections are secure and tight. I don't use surge protectors. All of my important network bits and pieces run on UPS. Speaking of UPS, my driver was here yesterday so I sent my old modem return with him.
Here's the most recent 1½ days of history. Pretty ridiculous.
Hey Remy, I just noticed something promising. This thing hasn't thrown any codes since a 20.2.1 associated with a bad thunderstorm late yesterday afternoon. Maybe the wizards are getting the problems sorted out.
Edit: I just noticed another positive sign. The diagnostic code is a steady 0000.0000.0000.0005 for the past 12 hours.
Good news Remy. It appears to be fixed. Only one thunderstorn series of failures and one 30.1.1 failure over the past 2½ days. Huge, monumental improvement over the revolving disaster that began nearly nine days ago with the installation of the replacement modem.
The hourly graphs are pretty clean now. Only a few red x showing with the same DNS Acceleration (N) but those blips aren't bad enough to throw a state code. The diagnostic codes are hanging in with 0000-0000-0000-0005 most of the time.
Thanks for getting this fixed for me. I'll post back if it goes down the tubes again but it sure appears to be business as usual now.
Update: The web acceleration crashed hard again this morning. The modem logged 25 transitions to 30.1.1 for a duration of 3¾ hours between 5:30 and 11 AM. Then we had a late morning thunderstorm that caused a slew of expected uplink/downlink state codes. The good news is, that fixed the total disater with the web acceleration. No more errors since the storm got off us 8½ hours ago
BTW, no number of MBX resets or cycling the WA control made a difference this morning. Please pass this along to the wizards. Maybe this will give them a clue.
Edit: Web Acceleration is back to the original pattern. It started going down shortly before 5 AM and is now crashing on 30.1.1 about twice an hour.
GW,
So no errors at all since that point? Interesting. Good to hear! I'll pass this along, please let us know if you have any issues with this going forward.
Remy
Oh jeez Remy Wall to wall 30.1.1 errors since Sunday morning. Please read all the messages. You missed the Sunday message and the Monday edit. Something is still badly broken.
Here's today's update. 20 Web Acceleration failures between 5 AM and 2 PM today for a total of 3½ hours of impaired operation. Today
Lizcan you please get me some help with this? I was sent a refurb modem but it just goes on and on and on.
- Liz5 years agoModerator
Hi GW,
As Remy has previously explained, the 30.1.1 code is a result of an event on the HughesNet side, so an equipment swap at your site won't have an effect on that code.
We've inquired about this with our engineers and will let you know once we have any news from them to share.
Thank you Liz I know it's a network problem and it sure is a strange one.
Wednesday morning update. As of this moment, only 1 transition to 30.1.1 has occurred since 5 PM yesterday. It went from 282 to 283 in 15 hours while there were 10 transitions between 2 PM and 5 PM yesterday. Too weird.
Thursday morning update: No 30.1.1 failures from 5 PM Tuesday through 4 AM this morning. Now, 12 transitions to 30.1.1 between 4 AM and 8 AM.
Friday update: Liz, It slowed down a bit. Only 19 transitions to greatness between 8 AM yesterday and 8 AM today. Is there any hope of getting this fixed any time soon? I have to do the windows updates on 4 computers next week and I'm afraid it will be a nightmare. I can't even do the google play updates on my phone over wifi unless I catch it right. It took about a half hour this morning to get 106 MB of updates completed
Unfortunately, I like to do most of my work and all of my updates between 4 am and 8 am when I'm in the Bonus Zone but that's when the crashing is most severe. I can use my phone to do all the windows updates but carrier restrictions require me to use a VPN which doesn't always work out well. I try to avoid it.
Good morning GW,
Just letting you know that our engineers are still investigating this. I'll post back once I have news from them to share.
Have a good weekend!
Hi GW,
Hi Liz,
I've had the Web Accelation turned off for the duration and was going to turn it back on today to see about things. I did three of my windoze updates this week during early morning bonus time and they all went well. No glitches and thankfully so because they were all major upgrades to Win 10 Pro version 2004. I did my last computer this morning It also went well and seemed to go much quicker but this was my main network computer with no wifi.
Fortunately I was able to get all the updates done in the Bonus Zone but I get up early anyway. They totaled almost 14 GB in my hourly history. That's some sick stuff. The windoze data hog strikes again.
After finding your latest message just now I looked at the modem and see they turned on the Web Acelleration, rebooted my modem and cleared codes for me yesterday afternoon. No codes ever since. Good stuff.
Thank you Liz. With all faith I have in you that's built up over the years, I know it's safe to mark this one solved.
Good to see, thanks GW. If you have any other concerns with your internet performance, feel free to drop by again!
- 3 months ago
