GW
6 years agoAdvanced Tutor
Web Acceleration failing
Recently my HT2000W with current Software Version: 3.4.6.26 (M) has been going to failure on Web Acceleration showing yellow on System Status page link and showing the Down status and red X for Web A...
Hi GW,
GW
Still failing on 30.1.1 but now it's completely shutting off with a lot of downlink and gateway errors. I hope this is the result of someone trying to fix my problem.
Remy
6 years agoModerator
GW,
30.1.1 itself is normally a network issue, however, seeing the rest of the state codes may be a power issue. Are the modem and cables plugged in securely? Are you connected to a surge protector, or directly to an outlet?
Remy
