I have a printer that is wireless and the tv that connects wirelessly (DISH). I have 2 computers that are hard wired.
Looking in the settings I can see that I can disable the 2.5 and 5 GHz channels (wireless) separately. My printer is on the 2.5 and the tv is on the 5. Why does it kick one computer on ethernet off if I uncheck the enabled on the 5 GHz . Is it crosswired or something?
Val
Solved! Go to Solution.
Never mind it is now working properly. Not sure why did that before.
Val
Val
