Hughesnet Community
Signal Strength seems to have become a bit erratic
GWEvans
Just last night, I suddenly lost internet connectivity.  It didn't last too long, may 5 minutes or so tops - no big deal, it happens.  But ever since then, it has done it a few more times now.  When I look at the signal strength, it goes anywhere from 104 (which I'm assuming is really good - everything works great) down to 30 which is bad, no connectivity to the internet.  Unfortunately, I neglected to jot down the state code when it has gone wonky, but I do have a history of the diagnostic codes:
Most recent first:
0000-0000-0000-0005  (everything is good with this code!)
0000-2000-0200-0007
0000-2000-0200-0007
0204-8000-0000-0003
0000-2000-0000-0023
0000-0000-0000-0027
The weather is good, and nothing is blocking the dish?
1 ACCEPTED SOLUTION
1 REPLY 1
C0RR0SIVE
